98 Voyager started ran for 2 secs stopped will now not turn over
Old Aug 24, 2010 | 07:25 AM
Philkaye's Avatar
Default 98 Voyager started ran for 2 secs stopped will now not turn over
1998 Voyager was running OK. Stopped and tried to restart engine it ran for few seconds and stopped; tried again and the same thing happen for few times. Then nothing; the engine will now not even turn over. The high level dash lights are OK (oil pressure etc) but the lower level gear position odometer and gauges are not working. Fuses appear OK.
Help please!
Phil (Australia)
Old Aug 24, 2010 | 02:53 PM
Merlin's Avatar
Hit the dash? Look at the immobilizer post.
Old Aug 24, 2010 | 03:38 PM
Philkaye's Avatar
Thanks for the advice. I have read other posts with similar symptons. If I understand them correctly I need to check the dash circuit board connection and maybe a 21 pin plug behind the heater panel. I undestand that there are 4 screwa to remove the heater panel; what is the simplist way to get at the dash circuit board?
Can anyone explain why this fault starts as a fault where the engine runs for a couple of sceonds and does this for a few times and then nothing - the starter will not turn. Is the because the circuits in the dash are linked to the SKIM system and if this complete immobilisation is a feature of the SKIM?
Thanks again for any replies
Phil
Old Aug 25, 2010 | 02:21 PM
Merlin's Avatar
No the immobilizer is not all in the SKIM, the SKIM reads the key checks the rolling codes with the PCM then the SKIM tells the PCM it's a good key and ok to start. When the communication is shut down between the two due to say dash or heater panel the immobilizer stays on. So you get a start stall then no crank. As the dash gets a lot of info from the PCM if comms is down you don't get fuel level rev counter and so on.
Old Sep 10, 2010 | 06:56 AM
bradleigh1977's Avatar
welcome to the world of immobiliser problems on your voyager!!!
its a piece of p&ss to take out the stereo surround, two screws at the top and then the ones by the ashtray top. the 21 pin is on the back of the heater slide cold/hot. if its melted ( ish ) then that may be the problem. get one from morpar or scrappy, mines worked fine ever since...
bradleigh
Old Sep 27, 2010 | 11:47 PM
Philkaye's Avatar
Thanks for all your helpful replies. I was unable to try out the potential remedies as the car was in the garage workshop. Anyway long story short, a new SKIM module and diode somewhere fixed the problem. I did get a new spare key out of the solution - which I needed.
darkcild101
May 20, 2015 01:03 PM
Hamilton22
Feb 3, 2015 10:18 PM
Red_5
Feb 9, 2013 09:32 AM
lilblkshp
Jun 23, 2011 11:09 PM
