AC blowing out hot air 2010 town and country
Old Jun 25, 2013 | 05:05 PM
cochrank's Avatar
Default AC blowing out hot air 2010 town and country
Group, I have tried to search this forum for my specific issue but could not find an answer. This all started on a vaction trip (~14 hr drive). I have a 2010 Town and Country (4.0L Limited). Initially at the start of the trip we found out that the rear AC did not work, just blew out hot air. The front worked so we just dealt with frozen feet up front to cool down the back (3 kids and 3 dogs tend to generate a lot of heat). We tried to look online while we were driving and from what we could see there were issues with rear condensors leaking and they stated to add freon. At a truck stop we purchased a kit (keep in mind one without a guage) and I added some. Once I did thay the front AC stopped working (blowing out hot air). We also smelt a brake burning-ish smell. Needless to say we just shut off the the AC for the remainder of the trip. Once we reached our destination after having the windows down the entire time I stoped to an Auto parts store and asked them. They stated it was probably low so I bought another kit. I bought a high quality one this time with a guage. They stated how it worked and when I initially hooked it up the guage stated it was overfilled. Went in and told them, took it to garage and had them reduce the pressure to the safe level (confirmed by the kit I have, in the green zone based on the outside temp). I did not have them look at it any further since it would have cost me more money and they did not have anything for fixing Chrysler vehicals and I am a do-it-yourselfer if you could not tell by now. Now with this I have verified the intial kit I bought was not needed and it ended up costing me extra money. Second that I do not have a leak. When I look at the compressor the pulley seems to "wobble" but when you turn on the AC the clutch does engage. The smell we were smelling might have been the clutch due to the high pressure. I have seen some posts on the interweb about the expansion valve and such. Any help would be great on what might be my issue or how to test the expansion valve (if that is it). I would hate to have to take it to the dealership since I know they will most likely just replace lots of things and are expensive.
Old Jun 27, 2013 | 10:06 AM
cochrank's Avatar
bump??
Old Jun 27, 2013 | 01:21 PM
do u have any experience dealer with an ac system and its works? if not I would advise not to mess with stuff U could easy blow something up or go blind from the fluid.
Old Jul 6, 2013 | 02:27 PM
Milkman21218's Avatar
It also could be over charged.
Old Jul 6, 2013 | 11:29 PM
not likey its a 2010
Old Jul 7, 2013 | 09:47 AM
I only made that statement because they had added more charge to it. I know that I have done it in the pass with the r134. Charged it to the max. And as temps rise it would not cool.
Old Sep 11, 2025 | 06:20 AM
iareamekanik's Avatar
Exclamation K.I.S.S. (keep it simple stupid)
Short history... 2009 T&C 3.8: A/C blows cold, no problem. Intermittently, it would blow HOT. I'm not talking "not cold", I mean full on hot air. After finding this forum, my blender door was broken, replaced it, and wahlah, right? NOT! It did it again 2X. Head scratching, what's up? Looking at eManuals' pictures and diagrams, I notice there is a temperature sensor on the evaporator in the lower corner. When I replaced the blend door, I noticed a few pine needles in the fan. Curious? Looked up and forward through the blend door housing and saw a few more that had been caught by the mesh. Because of the angle, I didn't realize how many. I removed the windshield wipers and cowl. On passenger side, from the left looking at the engine, there is a square hole, then four rectangular holes. I shoved a small vacuum hose into the first rectangular hole aiming back towards the square hole (towards the passenger door), and heard many leaves, and maybe a few acorns being removed. No problems since. The science behind, and why? The A/C system is designed to keep temps somewhere between 60 to 85 degrees F. If your A/C is chilling right along and the airflow is obstructed over that before mentioned evap temp sensor, it is no longer having the ambient air to warm the sensor. It will get super cold. Much colder than the lowest (60-ish), setting the system is designed to maintain. So, what does it do? It adds hot air as long as that evap temp sensor is covered, trying to get the temperature back into the 60 to 85 deg range. If the leaf drops away, your A/C goes back to normal. Leaf flips up in front of sensor, it blows hot again. Doesn't cost anything and can be done in an hour or two. I hope this helps. Be cool (as you want to be).
rsdodo
Sep 25, 2025 09:57 AM
Zplantpage
Sep 11, 2025 06:28 AM
Bman24
Jun 28, 2015 05:43 PM
Bman24
Jun 16, 2015 01:21 PM
bjbrunk
Feb 5, 2009 08:35 AM
