after market radio: no sound and no NBS relay installed ?
Old Jul 20, 2014 | 07:53 AM
dutch bus's Avatar
Default after market radio: no sound and no NBS relay installed ?
Hi Guys,
Yesterday I installed an aftermarket radio in my 2005 grand voyager limited 2.8CRD. Purchased all the required (iso & antenna) connectors and everything seems to work fine except of course: no sound.....
I scanned this forum for possible solutions and was planning to connect a wire from the radio directly to the NBS relay as suggested in a post on this forum and this Youtube post:
to activate the amp.
I opened the fuse box to discover that there is no NBS relay installed ?
But the original factory unit worked OK without relay installed, but aftermarket unit produces no sound. Does this mean there is no amp installed ?
How can I fix this ?
can I use any of the other relays to test this solution ?
My factory unit is a P05091610AC radio/cd. The only pin in the cars connector not connected at this moment is the one marked J1850 (nr 24)
Thanks.
Old Jul 21, 2014 | 01:49 PM
tfb's Avatar
tfb
Don't think the NBS relay is applicable to the 2,8's sound system.
The factory system outputs just 2 channels (L+R) which go to the amplifier. The amplifier is controlled by a data signal along the PCI bus from the head unit. The amplifier then distributes the L+R signal to all 6 speakers.
When I replaced my, I ran two extra cables from the new head unit and connected them to the rear speakers and used the existing L+R to feed the front speakers. I just removed the amp, cut the connectors off and joined the speaker wires directly.
The circuit diagrams can be found here
https://drive.google.com/folderview?...0k&usp=sharing
Regards
Richard
Old Jul 23, 2014 | 04:56 PM
dutch bus's Avatar
Smile Fixed !
Hi Richard,
Just like you said. With two extra cables it is fixed. I had eight speakers though but did not connect the tweeters in the D panel.
Thanks a lot !
Amplifier for sale
Old Nov 18, 2015 | 08:48 AM
estebanfree's Avatar
Keep the factory radio under the seat and connect four wires. power / aux power / ground and PCI. When you use the car amplifier will be turned on by factory radio and sound will be play by new radio
Old Nov 18, 2015 | 08:49 AM
I'm using this system becasue of I want to use factory 8 channel infinity amplifier.
QinteQ
Jun 10, 2015 07:39 AM
nickmabz
Aug 4, 2013 11:47 AM
sdeal5
Jul 13, 2013 01:35 PM
baggins
Dec 9, 2010 01:59 AM
carlovinchic
Apr 14, 2010 05:26 PM
