Air con removal new belt size help
Old Jan 8, 2015 | 06:58 PM
msd26129's Avatar
Default Air con removal new belt size help
My aircon pump is making a hell of a noise , so I want to remove it to have it checked out .. My problem is I can't be without the bus so does anyone no the part number and availability of an aux belt without aircon ..
Thanks in advance
Old Jan 9, 2015 | 10:23 AM
I'm pretty sure that all Voyagers are/were fitted with aircon as standard so you won't find a suitable belt listed in the parts catalogue.
Old Jan 9, 2015 | 02:38 PM
Been on here recently regarding CRD unit 2.5 or 2.8 but would think both would be the same. I got answer from a further back thread on guy removing his compressor and he said 6 Grooves..6PK1285 (1285mm long)..
Old Jan 9, 2015 | 02:51 PM
Serpentine Belt Without Aircon...By Rodger...2.8CRD..06.23.2014....Nice chap...
Old Jan 9, 2015 | 07:31 PM
Goggsy said you should see this thread .. .. .. and this thread - msd26129.
Old Jan 10, 2015 | 09:54 AM
rodger's Avatar
Hi
The spec of the belt is correct as per my post, just looked on the packaging ( I still keep the belt in the boot.just in case!) and its a Gates belt and has number 68388. If you do this temp fix, make sure the belt misses all the bolts on the timing cover, the belt does run close to one of them......but I ran for a year, 15,000 miles like it with no problems.
Rodger
Old Jan 24, 2015 | 11:14 AM
msd26129's Avatar
Thanks for the reply and all the help
Old Jan 25, 2015 | 11:11 PM
Nick1981-1's Avatar
yes roger took the words right outta my mouth (as meatloaf would say) if you are doing this the belt runs very close to the timing belt cover. a friend of mine did this and it shredded the belt... he found a contraption. .not sure where, that was like a blanking pully... like a dummy compressor unit that was just a pulley... 68000 miles later and its fine elbeit a tad hot in summer
Old Jan 26, 2015 | 03:27 PM
Interesting..Like a blanking pulley...Dummy tensioner comes to mind but its the fitting and lining it up as per compressor position.
Jason1969
Jul 8, 2013 09:35 PM
mjp100
Jun 26, 2011 10:10 AM
sean81
Sep 10, 2010 06:50 AM
tintin
Jul 11, 2010 05:29 AM
ohboyseth09
Apr 9, 2010 11:48 PM
