Alternator Fuse location T&C 2001
Old Jul 26, 2022 | 10:10 PM
Mutti's Avatar
Default Alternator Fuse location T&C 2001
2001 T&C Ltd. 80k miles. (was grandma's.)
New battery, bad alternator. Check fuse first?
We put 20K miles on with 2019 battery. Battery dies. Replaced. Alternator tests bad. Thinking about checking fuse first. Can't figure out fuse location from standard diagram common on internet. Can someone provide more fuse map details?
Recently had belt and tensioner replaced. Other ideas for bad alt? TY
Old Jul 27, 2022 | 01:26 PM
its a fusible link that's under the intake orange i believe . if you have voltage at the 12v connector to the alternators its likely not your issue
Old Aug 4, 2022 | 11:21 AM
gorilla's Avatar
there's a big ground wire i quess that is part of the charging system too that went south on my 2000 t+c 3.3l minivan.
it was replaced along with an alternator on mine.
that's what pepboys said and replaced on mine.
all that fixed the dead battery + charging issue's.
good luck
purplepuller
Apr 6, 2022 06:58 PM
toyota
Aug 6, 2021 02:07 PM
harrym
Aug 31, 2016 04:04 PM
mrobaer
Cirrus & Breeze
Sep 4, 2012 05:25 PM
Melssj5
Apr 25, 2012 10:03 PM
