auto Transmission issue
Old Feb 10, 2018 | 11:29 AM
yableep's Avatar
Default auto Transmission issue
Hi all,
Maybe someone has any experience or similar problem.
I have a 2007 voyager 2.8crd with auto transmission.
It is intermittent and mostly occurs on cold running.
On the second gear shift it hesitates a fraction of a second and then jumps in to gear. Mostly it happens after going down a curb or over speed bumps.
It doesn't do it on any other gear changes and on down shift. It very rarely does it when the engine is hot. I changed the oil and filter. The symptoms disppearedfor a couple of days and than it came back.
Weird or what!
Does a transmission fluid change needs to be reset in the software?
Thanks guys
Old Feb 16, 2018 | 04:51 AM
dieselvoyager's Avatar
I guess it's a RG model ?
You don't need to reset TCM when changing ATF oil , but if you leave battery disconnected the TCM will start new learn program depending how you drive.
Are you sure there is enough oil in trany ? drive a few miles and leave the car idle on level ground (in park) and check level . Chryslers is very sensitive to fluid level in trany not to much and to little will also kill it.
Old Feb 16, 2018 | 04:54 AM
And only use Mopar ATF+4 oil !
Old Feb 16, 2018 | 08:48 AM
yableep's Avatar
Hi dieselvoyager,
Thank you for your reply.
Yes, it is an RG model.
I only use ATF +4.
I will check the level this weekend and see.
Old Feb 17, 2018 | 11:18 AM
yableep's Avatar
Looks like there is a little too much fluid in there, went over the hot mark.
Old Feb 18, 2018 | 12:50 PM
Yes this could be the problem !
Old Feb 18, 2018 | 12:52 PM
If I remember right you need 5,5 litter ATF oil to an 2,8CRD !
Old Feb 18, 2018 | 12:57 PM
There is two marks on the oil stick warm and hot , if you only drow a few miles it's not suppose to go abow the warm mark !
Old Feb 18, 2018 | 01:31 PM
yableep's Avatar
The engine was hot after about an hours drive when I checked it, and the oil level was above the warm mark.
Old Feb 18, 2018 | 04:33 PM
