beeping when driver door open
Old Apr 11, 2012 | 08:41 AM
  #21
Alexmcilwaine's Avatar
Won't let me pm u motlow
Old Apr 11, 2012 | 09:41 AM
  #22
tommymca79's Avatar
Batyre on north queen street will charge your battery for £1, also my car was losing power for a few days but it's cured itself now
Old Apr 11, 2012 | 03:19 PM
  #23
Mine has had the issue for a good while now. Keeps draining batteries (tried new battery). Think I need a new ignition barrel as the string or something is broken in it as there is no resistance or spring back when I turn the key
Old Apr 13, 2012 | 02:33 PM
  #24
ChryslerCares's Avatar
Have you verified that its not the radio drawing power off the battery.
TSB 08-003-08
SUBJECT:
Hard Start/No Start Due to Weak Battery
OVERVIEW:
This bulletin involves checking for ignition off power draw caused by the radio and if
necessary replace the radio..
SYMPTOM/CONDITION:
Vehicle operator may experience weak or dead battery condition. This may be caused by the radio not powering down properly and keeping the communication buss awake causing a parasitic battery draw.
Old Apr 14, 2012 | 04:54 AM
  #25
I replaced the radio as the old one wouldn't put out any sound. Have had the problem before I changed the radio. Would a faulty ignition barrel cause a battery drain as it seems the spring inside the barrel is broken
Old Apr 15, 2012 | 12:48 PM
  #26
motlow's Avatar
sorry just moved house had no internet , seems very like ignition barrel/switch you should not hear any bleep when you remove your key unless it is at the auxiliary position , i'll get a look for you if you can wait till this coming weekend
Old Apr 16, 2012 | 07:13 AM
  #27
That would be brilliant. The ignition barrel has no resistance when I turn the key. To start the engine I have to turn the key all the way round to the right but the abs and handbrake light stays on. I then have to turn the key slightly to the left and the radio comes on, computer comes on and the abs and handbrake light goes off.
Old Apr 20, 2012 | 10:36 AM
  #28
Are u able to look at it for me motlow?
Old May 1, 2012 | 10:04 AM
  #29
are you able to look at it for me motlow?
provench
Oct 7, 2021 04:42 PM
sleninger
May 16, 2011 08:14 AM
ajs42548
Apr 12, 2011 08:17 AM
aavp96
Aug 10, 2010 09:02 PM
Saatu
Jan 1, 2009 11:20 AM
