Belt Squeak
Old Aug 27, 2024 | 08:08 AM
Vanguy006's Avatar
Default Belt Squeak
The belt tensioner went out on the van a few months ago. I replaced the tensioner and the belt. This squeak started shortly after. I thought it was the compressor going out but replacing that it still does it. Could it just be a bad belt or any other suggestion? I don’t know how it could be the belt tension when it was just replaced in march.
Old Aug 27, 2024 | 08:22 AM
Vanguy006's Avatar
Default Squealing Noise
Old Aug 27, 2024 | 09:43 PM
touch your alternator do you feel the same vibration ? can see the belt wobble from the ac compressor to the alternator If you turn off the ac does it go away ?
Old Sep 19, 2024 | 05:33 PM
Vanguy006's Avatar
Default Yes to both
It looks like the pulley is shifting some on the alternator when it starts squealing. I can feel a vibration in the alternator when it does that. It also only squeals when the ac turns on. Sorry it took so long to reply. Had family in the hospital. Is there a way to confirm it is the alternator before I replace it?
Old Sep 19, 2024 | 07:41 PM
take the alternator off and spin the pulley they are common for making noise.
Old Sep 20, 2024 | 01:46 AM
Vanguy006's Avatar
If it is the alternator. Can I just replace the pulley or do I need to replace the whole alternator? If the pulley is squeaking. Shouldn’t a new pulley fix that?
Old Sep 20, 2024 | 01:48 PM
Vanguy006's Avatar
Default Fixed
It was the alternator. All this time. I remember checking the alternator and it didn’t make a noise when you spun it but the pulley was crooked. Almost like the shaft was broke or something. Here’s a video of it spinning in case anyone needs it.
char181
Other
Dec 27, 2012 12:35 AM
speedy1on
Feb 28, 2011 03:08 PM
mediclev
Nov 17, 2008 10:48 PM
Daryl Baines
Nov 6, 2008 04:33 PM
evigilu
Mar 7, 2008 08:15 AM
