Blower fan problem
Old May 5, 2011 | 09:25 PM
ajedrummer's Avatar
Default Blower fan problem
My 2001 Town & Country LXI has the electronic dual temp control and it developed a problem today.
Today, after starting and stopping the engine a few times, when I started it, the heater/AC fan came on HIGH and would not adjust with the speed control. If I shut it off, the fan runs at top speed!
When I put the temp control on AUTO, the fan slows down, but still runs much higher than normal. The speed control dial for the fan as no effect.
The lights have been out on the control module for a couple of years. Is this the next phase and that module is now dead? Is there a way that I can try resetting it to see if I can clear this error?
Old May 10, 2011 | 08:48 AM
ettienne's Avatar
Old May 10, 2011 | 07:07 PM
Djinn-n-Tonic's Avatar
Agreed.....BUT......
terminology will royally screw you over on this one so be careful what you ask for......
ATC, or Manual , Both systems are built Both ways, but the resistors are NOT interchangeable....
Flip down the glovebox door and look inside...You will see 2 5/16 bolts holding a wiring connector. Remove it.....If it is CERAMIC, or it has 3 or 4 Metal windings in a steel Cage....It is a BLOWER RESISTOR
If it has an "ALUMINUM HEAT SINK " it is a Blower Fan MODULE
Better yet, take it out, and bring it with you to match at the parts store...
Old May 11, 2011 | 06:03 AM
ajedrummer's Avatar
Default Problem fixed
Yes, the resistor module was it!
I was very happy it was not the heater module - that is much more expensive.
Thanks for the input.
JamesEiland
Mar 11, 2012 08:31 PM
colbertgang
Apr 26, 2009 09:30 PM
rkluck
Mar 29, 2008 03:14 PM
United1
Jan 2, 2008 10:45 AM
greenman
Mar 2, 2006 05:19 PM
