blower motor
Old Oct 3, 2011 | 09:43 PM
stumpy78's Avatar
Default blower motor
We have a 2001 town & country limited, the front blower motor does not work at all; i.e at any speed settings. The rear blower works, I switched fuses, front to rear, and no change. Any suggestions?
Old Oct 3, 2011 | 10:37 PM
auto temp control?
Old Oct 5, 2011 | 12:39 PM
stumpy78's Avatar
Yes, three zones. Driver, passenger and rear.
Old Oct 5, 2011 | 01:43 PM
more then likely the blower motor resistor module
Old Oct 6, 2011 | 08:25 AM
stumpy78's Avatar
Thanks. Are there any checks first, or go ahead and replace the module. Appreciate you sharing your knowledge.
Old Oct 6, 2011 | 03:18 PM
u can add power to the motor and see if it moves that's about all u can really do though
Old Oct 20, 2011 | 02:51 PM
stumpy78's Avatar
Smile 2001 blower motor
I checked the 3 wire connector and had 13.8v with the van running between the black/orange and dark blue. and had 13.8 between the dark blue and light blue. Had nothing on the second connector (black and green). I gather thats the pigtail to the blower motor?
I'm slow with repairs, life is full with kids and work.
Old Oct 20, 2011 | 04:58 PM
Raptor 07's Avatar
C1 connector
Pin A - Black/orange stripe - Ground
Pin B - Dark blue/light blue stripe - Control voltage from A/C heater panel
Pin C - Dark Blue - Primary voltage from relay
C2 connector pins 1 & 2 to motor
If you like you can jumper pin C to pin 1 then jumper pin 2 to ground to try to spin the motor.
Old Nov 8, 2011 | 09:11 AM
stumpy78's Avatar
No luck with the blower module. Replaced it yesterday and no change. Looks like the blower motor. I should of tried power to it before the buying the module. Sounded reasonable.
Old Nov 14, 2011 | 06:59 AM
stumpy78's Avatar
Blower motor works, I used a 12v car battery and the blower ran fine. Is it possible I was sent a bad blower module?
