Body Control Module
Old May 29, 2013 | 09:37 PM
Varessa's Avatar
Default Body Control Module
The body control module went out again this week after it's second replacement. What could be causing this? I just want it fixed...it is scary driving a car with this issue.
Old May 30, 2013 | 02:44 AM
Raptor 07's Avatar
Model year and symptoms would help.
Old May 30, 2013 | 05:55 AM
Varessa's Avatar
Default bcm
Sorry...2004 Chrysler T&C. Symptoms: Headlights, Tail Lights, Wipers, Windows, A/C, Radio, Horn All Stop Working With No Warning.
Old May 30, 2013 | 08:58 AM
andyb2000's Avatar
Might be a long shot, but does the coolant water bottle overflow/exhaust/outlet (whatever it is) pipe point straight onto a rather large loom of wires that have 'joining' tape around them?
This is what I found on mine, and discovered water droplets always sat on this cable/joint. I redirected the overflow pipe elsewhere and my BCM doesn't seem to go nuts as often as it used to.
Coincidence possibly, worth a go? probably!
Old May 30, 2013 | 04:41 PM
Raptor 07's Avatar
How long did the first replacement BCM last? Was any maintenence performed just prior to the start of this?
The BCM gets power directly off the battery bus from 4 sources. Did any of the 4 fuses blow?
BCM fuses:
40 amp fuse #20
20 amp fuse #24
40 amp fuse #19
15 amp fuse #14 (IOD)
Did any other systems die such as power doors, door locks, brake lights, interior lighting, turn signals, power outlets, etc?
When you say the A/C died does that mean blowing hot air or no air at all? Any other heater A/C panel functions stop working?
What I'm getting at is it appears (looking at wiring diagrams) the Front Control Module (FCM) may be just as likely a culprit. More info will help determine that.
Old Oct 24, 2013 | 07:53 PM
Xoloski's Avatar
Where does one get the schematics for Chryslers, specifically a '94 Ney Yorker?
Thanks,
amadsen
Mar 24, 2012 07:17 PM
PapaGeorgio
Aug 20, 2009 02:44 PM
Bubble_City
May 4, 2009 06:23 PM
CSPEISER
Jul 24, 2007 11:25 PM
