Body control unit replacement
Old May 13, 2014 | 12:38 PM
robby-britton's Avatar
Default Body control unit replacement
Hi, I have a 2002 Voyager with a faulty body control unit. The dash is totally dead and the indicators don't work.
Chrysler no longer produce the unit and I don't want to scrap the car but it can't pass MOT with no working indicators or dash lights.
Can I buy a second hand unit to fit to the car? Any thoughts?
Old May 13, 2014 | 01:20 PM
tfb's Avatar
tfb
you could try sending it to BBA-reman BBA reman. ABS, ecu's, throttle bodies, air mass meters, and catalytic converters Thev'ye sorted out modules for me in the past. Not the cheapest, but they are good.
Are you sure it's the BCM and not the IPM?
Regards
Richard
Old May 14, 2014 | 03:03 AM
Hi Richard
Thanks for the reply. I've phoned them already and gave them the part number. They say the computer in my car can't be repaired. If it was 6 months older with the older unit then they'd be able to.
My only option is to buy a second hand unit but I don't know if it will work and I don't really want to waste money buying it unless someone on here has experience to say if it can work or not.
Old May 14, 2014 | 03:09 AM
Just read your post again. What does the IPM do? I spoke to BBA and they said it's likely the body computer due to both the symptoms and the fact it all died after I jump started the car. I've searched high and low for a wiring diagram so I could trace the wiring but can't find anything. Every wire on the instrument cluster is either dead or has earth (I assume signals for the dials)
Old May 14, 2014 | 05:16 AM
The IPM [integrated power module] is the power distribution box box near the battery with all the fuses & relays in it, inside the lid is a pictorial representation of each fuse & its value & location. It is variously blamed [with good reason] for :
- trouble starting the vehicle
- stalling & LIMP mode
- headlights going out
- fuel pump not shutting off
- random alarm / horn windshield wiper issues
Your starting point would be to pull the NEG cable off the battery - wait 15 minutes - replace the NEG terminal - and start the car - what's happening now ?
Old May 14, 2014 | 06:56 AM
Hi QinteQ and thanks for your reply,
I have disconnected the battery overnight and still have the same issues. The indicators do nothing and the entire dash and upper level warning lights are all dead. The engine starts ok and doesn't cut out and the other lights and wipers work fine.
The alarm does go off on its own which I've tracked to a power drain caused by the ignition barrel. The button that detects the key not removed from the barrel is stuck and is causing a relay in the IPM to stay on. The alarm only goes off when the power in the battery gets very low. This should be an easy fix but I'm more concerned about the dash for now.
Old May 15, 2014 | 04:01 AM
tfb's Avatar
tfb
circuit diagrams can be found here, they are for a 2007 but most should be the same
https://drive.google.com/folderview?...&usp=drive_web
Regards
Richard
marty1966
Apr 2, 2018 04:32 PM
Huggy59
Oct 17, 2011 06:23 AM
stoneyh1
Oct 7, 2011 09:34 AM
markseb03
Jul 30, 2009 12:58 PM
alan
Nov 19, 2008 01:22 PM
