a/c thru the defrost setting only
Old Jun 12, 2017 | 06:08 AM
tinamug's Avatar
Default a/c thru the defrost setting only
I have a 2007 town and country. The only way the a/c will come on is if it is on the defrost option. Once the selector is changed from defrost to vent, floor, or floor and vent the a/c compressor kicks off. It does stay cool for a while but it eventually just goes warm. Can someone assist me with this issue?
Old Jun 23, 2017 | 02:19 PM
silentdub's Avatar
Sounds like the A/C switch is bad. The A/C turns on automatically with the defrost option but requires the little A/C switch be pressed and lit up on any other setting.
Put your fingers on the relay while someone turns this switch on/off, the relay should click, otherwise it sounds like a bad switch.
EVillarreal
May 30, 2017 11:25 AM
Art5
Aug 18, 2015 01:21 PM
Freedom Hudson
Jun 24, 2014 06:10 PM
bbatts
Apr 14, 2011 10:26 PM
nanu73bear
Sep 24, 2007 12:31 PM
