Camshaft position sensor voltages
Old Jul 9, 2012 | 02:48 PM
nelpasa's Avatar
Default Camshaft position sensor voltages
With KEY ON,not turning, getting 4.98 volts
With KEY STARTING, engine turning, 4.99-5 volts,NO LOW VOLTAGE.
measurements from gray/red wire to battery ground.
want to know if that is correct.......
Old Jul 11, 2012 | 03:02 PM
HellasHaggis's Avatar
Default Camshaft Position Sensor
If you are getting a P0344 Error code - Camshaft Position Sensor Circuit Intermittent - be sure to first check your battery voltages. (Apologies if this is deemed a daft suggestion, some have been caught out by this?)
Alternately, regarding the Camshaft Position Sensor the manual states:
P1391-INTERMITTENT LOSS OF CMP OR CKP
Visually inspect the related wiring harness. Look for any chafed, pierced, pinched, or partially broken wires.
Visually inspect the related wiring harness connectors. Look for broken, bent, pushed out, or corroded terminals.
Ensure the Crankshaft Position Sensor and the Camshaft Position Sensor are properly installed and the mounting bolt(s) tight.
- CAMSHAFT POSITION SENSOR (GAS) - BLACK 3 WAY
- CAV - CIRCUIT - FUNCTION
- 1 - F888 18BR/PK - 8 VOLT SUPPLY
- 2 - K900 18DB/DG - SENSOR GROUND
- 3 - K44 18DB/GY- CAMSHAFT POSITION SENSOR SIGNAL
- CLUTCH PEDAL INTERLOCK SWITCH (MTX) - BLACK 2 WAY
- 1 - T141 20YL/OR - FUSED IGNITION SWITCH OUTPUT (START)
- 2 - T751 20YL- FUSED IGNITION SWITCH OUTPUT (START)
- CRANKSHAFT POSITION SENSOR (GAS) - BLACK 3 WAY
- 1- F888 18BR/PK - 8 VOLT SUPPLY
- 3 - K24 18BR/LB - CRANKSHAFT POSITION SENSOR SIGNAL
Old Jul 12, 2012 | 08:08 AM
nelpasa's Avatar
I am getting code P0301. Replaced plugs, ign coil and fuel pump. Won't start
Old Jul 13, 2012 | 07:34 AM
Hi, I think code P0301 is a cylinder 1 misfire. To be sure, check cylinder compression and fuel pressure, typical cylinder compression readings, I believe, should be between 125psi and 160psi.
A colleague advised that you might also check the idle air control valve and the air intake tube from the air filter to the throttle?
Old Jul 16, 2012 | 01:07 PM
nelpasa's Avatar
Checked 2,4 and 6 cylinders compression.2(80psi),4(75psi) and 6(80psi). Could it start with those pressures?
Compression should be 170 to 225 according to the book.
Will I have to replace the rings only?
Old Jul 19, 2012 | 03:58 PM
nelpasa's Avatar
COMPRESSION DID NOT CHANGE (70psi) AFTER SQUIRTING OIL INTO CYLINDER, DOES THAT INDICATE BAD VALVE SEATS?
Old Jul 25, 2012 | 02:28 AM
TrentMassey's Avatar
Old Aug 24, 2012 | 07:21 AM
chromer2828's Avatar
Hi sorry to but it on the post but having real grief getting my car to start. Its a chrysler voyager 1999 2.5td, when i take the crankshaft plug off and switch ignition on the voltage is only 0.1volts???? There is only 2 wires going to the sensor and i assume one should send a supply current, any help would be greatly appreciated
thanks Craig
Old Aug 26, 2012 | 10:49 AM
nelpasa's Avatar
Originally Posted by chromer2828
hi sorry to but it on the post but having real grief getting my car to start. Its a chrysler voyager 1999 2.5td, when i take the crankshaft plug off and switch ignition on the voltage is only 0.1volts???? There is only 2 wires going to the sensor and i assume one should send a supply current, any help would be greatly appreciated
thanks craig
the wiring diagram tells the operating voltage of the sensor. In my town and country is 5 volts
nelpasa
Jul 9, 2012 02:46 PM
sumncguy
Apr 17, 2012 07:27 AM
manshack_one
Dec 13, 2010 06:59 PM
dcm1971
Oct 13, 2008 12:10 PM
jjmenard
Sep 6, 2007 05:33 PM
