Car vibrates / shaking when braking
Old Dec 21, 2014 | 05:50 AM
  #21
If you spray cold water on them while hot
As Leedsman often says, uneven deposits of friction pad material transferred at prolonged high temperatures are 99% of the cause of thickness variation and brake judder / flutter. The only other [infrequent] one I've come across is individuals who use home or garage based high pressure washers to clear dirt and particularly winter 'salt' from the disk / ABS sensor area leading to a 'warped' disk.
Old Oct 3, 2017 | 01:44 AM
  #22
shottootto's Avatar
I had a similar problem on my 2004 Neon.Replaced pads and rotors, but the problem persisted. Turned out the problem was dirty ABS wheel sensors. I cleaned the sensors with a brush and paraffin and problem solved. The sensors are on the inside of the front wheels. To diagnose if the problem is ABS, remove ABS fuse (in engine compartment) Drive the car (remember no ABS!) and test the brakes. If the vibration is gone, problem is with ABS.
Old Oct 14, 2017 | 11:52 AM
  #23
kenvb's Avatar
i agree, this time change the calipers as well as rotors and pads. get them from Prime Choice auto.ca or com depending if your in Canada ir US. free shipping and 1/4 price of anywhere else. http://www.primechoice.com/
bambuzas
Apr 10, 2012 09:16 PM
efanatic
Sep 16, 2011 08:41 PM
integlspwr
Apr 18, 2011 12:42 PM
arojas
Jun 25, 2010 02:04 PM
KA3AX
Sep 29, 2007 02:05 PM
