chrysler T&C (2001) power steering
Old Mar 19, 2010 | 05:15 PM
fkthomas's Avatar
Default chrysler T&C (2001) power steering
I lost power steering in my van, it was making a loud noise from the steering column. I noticed I was low on fluid so I added some. The noise went away but my steering is very tight, and I am losing fluid underneath.
What are the possible problems and $$ to fix?
Thanks in advance.
I also drove it 3-4 miles that way. Don't know if I could have done further damage...
just added 32 oz of power steering fluid with stop leak additive. I checked underneath the car and fluid was draining onto garage floor significantly.
Help?? Is it as simple as a fixing the leak? Is the pump not functioning (when I turn engine on, fluid level went down significantly) ? What are symptons of rack issues?
Old Mar 20, 2010 | 10:34 AM
fkthomas's Avatar
I fill up resevoir and when I turn on the ignition, the fluid then drains out under the car...any thoughts?
Old Mar 20, 2010 | 12:20 PM
fkthomas's Avatar
i am sure there are multiple areas where the leak can be present, however can we rule out rack or pump issues?
I guess if the pump is cracked, the leak could be there...but it seems that the leak is somewhere else
Old Mar 20, 2010 | 12:51 PM
any place that has fluid going through it can leak u are the only one that can see where it is coming from if u cant find it then pay some one to find it for you.
Old Mar 20, 2010 | 04:12 PM
fkthomas's Avatar
thanks. Not able to find the source yet. But just wondering if the problem could be worse than a simple leak...
Victor L
Jan 12, 2014 08:38 AM
lotsip81
Sep 15, 2010 12:40 PM
lotsip81
Jul 30, 2010 11:22 AM
chryslervan
Mar 21, 2009 10:07 PM
3.3lxbluevan
Feb 15, 2009 07:06 PM
