Chrysler Town Country Error Code U110C U0140 U0155
Any suggestions? Thank you!!
Chrysler Town Country 2005 3.8
Symptoms;
Dashboard didn't light up. And power sliding door didn't open
Sat for an hour; Then started up the van.
Dashboard working. Lit up, and sliding door is working.
- But Engine light now came on. Error codes; U110C U0140 U015
Was suggested to replace the ECM (engine control module) or ECU (engine control unit).
Symptoms;
IF mine, I would start off cleaning the battery terminals and posts and coating with Dielectric grease. Then trace back the ground cables from the battery and clean those connection points along with Dielectric grease also. There is also a ground small gage wire near the drivers side strut tower...check for that also.
braganfamily
Apr 8, 2019 03:53 AM
H.sicilian
Jan 23, 2018 11:36 AM
slvwmt
Aug 22, 2014 02:12 PM
Jersey Mike
Mar 1, 2013 03:34 AM
