Chrysler Voyager 1999 Brake lamp blinking help!
Old Jan 2, 2014 | 03:14 AM
Leedsman's Avatar
One would assume you've done the "key-dance" to check for errorcodes? If codes are present, this could point you to to root of the trouble.
Also, if nothing shows from errorcodes, check if you have a dodgy warning switch on brake master cylinder, the one that would indicate low brake fluid. I think of this one as you say the blinking brake light comes on immediate without engine running.
Leedsman.
Old Jan 13, 2014 | 07:37 PM
Bazer79's Avatar
What do you mean key dance? I only have turn the key on, not all the way so engine starts and the brake lamp starts to blink and i have tryed to change the master cylinder with the switch that you are telling without any help. I have made a video on youtube link is here:
Old Jan 14, 2014 | 03:34 AM
Leedsman's Avatar
The "key-dance" is a means of accessing errorcodes from the micros without the need for a codereader hookup to the diagnostic socket. It involves switching the ignition on and off I think four times (there are PLENTY of instructions on this website how to do) and viewing the mileometer to see the code(s) -- a nice touch from Chrysler.
Leedsman.
Old Jan 14, 2014 | 04:32 AM
tfb's Avatar
tfb
I've had a look through some drawings and there are a few points to test
Circuit diagram here
https://drive.google.com/file/d/0Bw6...it?usp=sharing
Test the voltage from C2 pin 1 and c2 pin 8/9 (manual or automatic) and that should be a steady votlage, but most likely it's going to be the combined flasher module given the regularity of the flash.
Regards
Richard
Old Jan 14, 2014 | 06:22 AM
  #15
chrysler1's Avatar
might sound to obvious, have you tried new bulbs.
Old Jan 14, 2014 | 03:04 PM
  #16
Bazer79's Avatar
Wow i didnt knew that, gonna try that later!
No i have not tryed new bulbs, where should i change?
Old Jan 15, 2014 | 12:01 PM
  #17
chrysler1's Avatar
Sometimes if a element is faulty but still works,the system goes to fault mode.
Old Jan 24, 2014 | 02:32 PM
  #18
Bazer79's Avatar
Tryed to find how to do key dance for Voyager 1999 without luck, i have tryed to switch ignision 3,4,5 times without luck maybe im doing someting wrong..anyone who knows?
Old Jan 24, 2014 | 06:15 PM
  #19
It's more knack [the part seconds between moving the key] than science, keep trying - you'll get it !
on/off
on/off
on
then wait .. .. the 'P' codes appear in the 'odo' window
Old Jan 25, 2014 | 02:07 AM
  #20
tfb's Avatar
tfb
Doubt the key dance will show anything useful for this fault. It will give you the P codes, but not the body, chassis, abs, chassis etc.
Regards
Richard
