Chrysler Voyager 2.8 CRD Automatic gearbox problem
Old Jan 9, 2020 | 09:09 AM
Todor's Avatar
Default Chrysler Voyager 2.8 CRD Automatic gearbox problem
Hello,
i have the same problem. All the symbols are rounded - R, D, P,.... When i move the changing stick nothing happens. i booked a diagnostic next week so will see what errors will be shown.
Does anyone had the same problem? Any suggestions about the reason.
Just one day when i started the engine and the gearbox was not working without any problems before that day.
Is it possible when the gearbox oil need be changed to happen like this?
Thank in advance.
Old Jan 30, 2020 | 01:30 AM
IATinBLACK's Avatar
Your car is in limp home mode. The reason can be as simple as bad battery.
Try the key dance if it shows some codes.
Or is this already sorted out?
Old Jan 30, 2020 | 01:53 AM
Todor's Avatar
Key dance showed only the code for not original key.
I fixed the problem. The problem was bad electrical installation. Some bad connection of wires. Also something of Power control module the mechanic said.
Thank you for your reply.
Scottmc21
Jul 27, 2019 12:02 PM
Grizz
15
Jul 23, 2015 04:35 AM
Mark Houghton
11
Mar 16, 2014 06:47 PM
Jon Watsham
Nov 20, 2013 10:00 AM
