Chrysler Voyager Stalling/Cutting out issue
Old Jun 22, 2011 | 03:01 PM
Virg///M3's Avatar
Hmm...Your problem sounds a little more serious if it's shutting off while driving & no codes. Definitely sounds like gas or computer related.
Mine on the other hands is only at idle, stopped or as I release the accelerator at very low speeds (such as 1-5 mph). I have a Mechanic working on it, & he is starting with the T.P.S. (Throttle Positioning Sensor).
Old Jun 22, 2011 | 03:25 PM
tksluke's Avatar
Originally Posted by Ming the Merciless
Hi again. I would have the garage check the injector pressure & fuel return. Does it rev cleanly from idle and under load? Is there any misfire ? Is the electrical connector on number one injector in good shape? Check for broken or damaged wire there.
Thanks, but the injector connector is brand new nearly and the revs are really clean, never misfired under load or idle, if the injector doesnt work wouldnt the turbo stop working also?
Old Jun 23, 2011 | 03:30 PM
Ming the Merciless's Avatar
Turbo works on exhaust gas pressure. If you have a sticky injector or intermittent fault, then as long as the engine revs up then you will have pressure enough to spin the turbo. Virg///M3 may be right about a computer glitch but check the easy (cheapest) things first. I coudn`t rule out computer issues entirely but with diesels it`s almost always fuel or air issues.
Old Jun 24, 2011 | 09:31 AM
tksluke's Avatar
Been informed the injector itself is brand new and fully checked out my best guess is an electrical fault and its very intermittent
Old Jun 24, 2011 | 01:35 PM
  #15
The dreaded intermittent fault. Notoriously difficult to pin down.Next thing to look at is all electrical connections including earth straps, working your way back to the brain. (Cheapest first) Once you are sure everything checks out ok if it still persists then ignition key barrel could be a possibility. I sounds daft but if there is a problem there and you have a big bunch of keys dangling from the ingnition key ....... ! I had a similar problem with a Saab & it turned out to be a worn barrel. Hard cornering with a big bunch of keys hanging of it caused a short & misfire, while it ran fine in a straight line!
Old Dec 5, 2011 | 08:13 AM
  #16
tony brice's Avatar
Default crd cutting out
i have a 2.5 crd with engine cutting out.if you remove battery and tray
you wil find some wires wich are not insulated. check grey wire with pink
chaser this wire rubs on chassis.this wire triggers fuel pump.check this
had no problems ever since
Old Dec 6, 2011 | 09:34 AM
  #17
Virg///M3's Avatar
My problem has finally been resolved, I don't think it will resolve your problem but with these vehicles who knows. My T&C ('03) kept stalling while idle or stopping at low speeds. Turns out that it was the Cam & Crank sensor. Actually, it was only one of these my my Mechanic told me its best to replace them both, so we did and after two months it has yet to stall. Hope this helps in any way. Good Luck.
Old Nov 7, 2012 | 09:00 AM
  #18
merlin1973's Avatar
Any results on this as my 99 deisel is the same
voyager_dan
Sep 8, 2011 09:06 AM
nick bowler
Jul 1, 2011 04:58 PM
actd
Apr 26, 2010 05:16 PM
Arto
Mar 15, 2010 11:51 PM
Yeti
Dec 12, 2006 02:25 PM
