clutch pedle too hard
Old Feb 13, 2009 | 07:45 AM
raj's Avatar
raj
Post clutch pedal too hard
hi, can anyone help? i have a voyager 2001 2.5 turbo diesel.
the clutch pedal was too hard to press when changing gears. ,i thought it was the clutch so i replaced it, but it's still the same.
Old Feb 14, 2009 | 12:44 AM
glowplug's Avatar
Check whether it is a cable actuated clutch or an hydraulic one. If cable then oiling of the cable may be required. If hydraulic check that the assist spring on the pedal hasn't come off or broken and also check for any interference at both the pedal and clutch fork.
Old Feb 14, 2009 | 10:49 AM
bdab's Avatar
if its hydraulic was either the slave or master cylinder changed? My toyota did that and it was miss matched master and slave. you need a 1:1 ratio in bore size. so if your master is a 3/4 inch bore then your slave needs to me a 3/4 inch bore. when I did the V8 swap in my LandCruiser I had to mix and match parts to get a slave that would work with the Toyota master.
Dodgegirl19
Apr 10, 2011 06:08 AM
symphonic81
Jan 12, 2011 09:21 AM
mn_hokie
Apr 14, 2007 02:06 AM
Tony24md
Dec 15, 2005 12:11 PM
Dodgegirl19
Nov 18, 2005 02:24 PM
