Code was P0235 now and P0113.
Old Nov 28, 2015 | 06:43 AM
andyb2000's Avatar
What you need is a bit of electronic gadgetry to log the voltage output of the sensor as tfb mentions.
Gives me an idea for a project sometime, not sure if you're an electronics person or not but an Arduino with SD-card shield would probably do the job nicely, set it to log two voltage sense inputs using a voltage/resistive divider on each (allow up to 12v to be safe I'd say), that way you can take your reference voltage going into the MAFS and then it's output/return, log it's output every 30 seconds (or smaller delay, depending on the sample period needed) say and give it a whirl.
Not exactly a quick fix/check but it's a potential way of doing the same on a budget.
Old Nov 28, 2015 | 09:33 AM
tfb's Avatar
tfb
You can pick up USB scopes on ebay from about £50 upwards, though a Arduino or PI gives you lots of other things you can do. Sample rate would need to be at least 50ms, given that a fault is logged if the reference exceeds the parameters for 100ms.
Spending £50-80 on a scope for just one fault is hard to justify though.
Regards
Ricahrd
Old Nov 28, 2015 | 01:38 PM
Thanks guys I'll think this over with a strong drink. As to £50+ Christmas is looming and I'm on a budget. But if the rain stops, eventually, I/we'll get back on it. But again thank god its still useable.
Christopher Gajewski
May 31, 2012 02:59 PM
jwms
9
Feb 23, 2011 08:44 PM
sassy
Jan 7, 2011 06:06 PM
chriseisenbraun9
Aug 1, 2009 05:12 PM
