Code PO401
Old Oct 6, 2008 | 11:29 AM
rxhinojo's Avatar
Default Code PO401
My engine light is on and has code PO401. I had previously replaced egr valve assembly. Now light is back on and it reads egr insufficient airflow. 99 T/C 3.3. Can someone tell me what I need todo to fix problem.
Old Oct 6, 2008 | 06:07 PM
Default RE: Code PO401
get a better part
Old Oct 6, 2008 | 09:32 PM
Check the hoses too.
Old Nov 14, 2008 | 07:51 AM
rxhinojo's Avatar
Thanks, I am going to check the hoses first to make sure there is no leaks. Does the hose that connects the air box to the motor have anything to do with this problem.
Old Nov 14, 2008 | 05:24 PM
P-0401 EGR SYSTEM FAILURE
POSSIBLE CAUSES
EXHAUST LEAK
INTAKE MANIFOLD RESTRICTED
EGR BACK PRESSURE TRANSDUCER DEFECTIVE
EGR VALVE ASSEMBLY DEFECTIVE
EGR VALVE ASSEMBLY MOUNTED INCORRECTLY
EGR SYSTEM FAILURE DOES NOT REOCCUR
EGR TRANSDUCER LINE BLOCKED
EGR VALVE ASSEMBLY DIAPHRAM DEFECTIVE
VACUUM SUPPLY TO EGR SOLENOID INADEQUATE
rxhinojo
Feb 18, 2012 07:17 AM
cyrone
Mar 24, 2011 11:39 PM
Mort439
Jul 8, 2007 09:25 AM
