CRD injector cleaner
Old Jul 8, 2014 | 05:43 AM
TimmyTim's Avatar
I've looked into this for years now. Merc took one of there cars across Europe(If I remember correctly) and were concerned about the quality of the diesel In certain countries so used 2T oil in the derv! If its good enough for them! Then its good enough for me! I've been using it for years now in 3 different vehicles(Toyota/VW/Chrysler) without any problems.
You pays your money! And takes your chance...
Old Jul 8, 2014 | 05:56 AM
TimmyTim's Avatar
If people dont want to use 2T low ash oil in there derv then thats there choice! Use BG244 instead of make like Forte as it has a higher POA in than others on the market! But you will see that the main fluid in these are 28sec kerosene! And as most know diesel is a 35 second oil!... There will always be people and view's on both side's of the fence. Some would argue that using a fuel like Shell V-Power you shouldn't need any other additives! And I agree in the most part! But I like to go above that! Guess that's why our GV runs on Mobil 1 0w-40 with its very high TBN/Flash point and Viscosity Index and gets changed every 6k...
Old Jul 8, 2014 | 06:10 AM
Vmaxxer's Avatar
Actually I spend the past several hours reading thread after thread on the internet about adding 2stroke oil to diesel.
All the evidence I could find about the positive effects are anecdotally and talk about "feeling" more powerful, 'seemingly' less sound form the engine, and a slightly noticable advantage in MPG. But wherever I dig and look I fail to find proper scientific testresults. Why wouldn't there be any?
I read a lot of warnings about using the 2stroke oil in modern diesels as in CRD engines, so unless I dig up some more substantiated evidence I wait before using it
has anyone found a trustworthy thorough test report on this subject?
Old Jul 8, 2014 | 06:19 AM
Leedsman's Avatar
Quite so, Vmaxxer, one of the main reasons fuel suppliers add some processed veggie oil in about 5% proportion to the diesel fuel is to aid diesel injector pump lubrication since governments insisted the sulphur be removed from the diesel: At this, veggie oil is very good.
I've spent much time testing whether the various additives to both engine oil and diesel fuel work -- and I can answer in one phrase -- they don't, -- except with the case of "cleaning" diesel such as Shell's V-power, BP's Ultimate, and that's a "maybe", depending on whether the injectors actually need cleaning or not.
All diesel in EU and UK must be at least cetane 51, and that's all be necessary for a normal diesel, made to work with that fuel. The danger with diesel is water in it, algae, and other rubbish due to bad storage/handling.
Pouring additives into the engine oil in the hope of reducing friction is another lost cause. I've done the testing and there is no difference in fuel consumption. In fact, there is a danger of clogging the oil filter with some additives, esp. the PTFE ones.
The only way to reduce the main bugbear, cold-engine friction, is to warm up the engine first before you ever start it, such as with a Webasto coolant heater. This also reduces cold-engine wear. Absolutely obligatory with racing engines BTW.
If you want to reduce expensive fuel consumption, look at the following.
1) Have a diesel engine rather than a petrol. Also, because LPG is half the petrol price in UK, there is a cost-effective advantage with a petrol engine converted to LPG.
2) Watch how you drive. If your right boot is always heavy, you'll pay for it. Hypermilers get around the same as anyone else, but use less fuel. They also pay attention to the following...
3) Maintain your vehicle properly. Dragging brakes (a common one on the rear drum brakes with a GV.), underinflated tyres, jammed-open thermostats all add their demand for fuel.
4) Check your fuel consumption religiously at every fill-up with the brim-brim method, not relying entirely on the computed read-out. This gives you an early 'alert' if something is wrong, like clogged injectors.
5) Once you have everything right as far as humanly possible, forget trying to make it better on fuel. You will have hit the "brick wall". Trust me, you will have to burn that amount of fuel to get that vehicle around.
Leedsman.
Old Jul 8, 2014 | 06:32 AM
  #15
TimmyTim's Avatar
As I said earlier... this might not be for eveyone! But I like to use it! But thats just me. You won't get anymore mpg out of the car by using it! I can only give my results in using it and the emission test results from the MOT. Now they could be low because I have used BG244 and the Archoil product's in the past! Or it could be simply down to the fact I run the car on V-Power!?.., or that I used a very good oil?
Old Jul 8, 2014 | 06:57 AM
  #16
Vmaxxer's Avatar
Tim, out of curiosity: But why would you use 2stroke oil if you already use Vpower diesel?
According to the theory they achieve the same result.
Another issue where I cant get my head around is that if the additives (the various flasks at the auto shops and the 2 stroke oil) are really needed on a regular basis, why wouldn't the car manufacturers publicly advice it? I never ever seen or read an advice from the main manufacturers and it would be to their advantage.
My logical sense dictates me that with the "premium" fuels like Vpower and such that void in the market is already filled.
But I am still intrigued and I keep looking for "official" test results.
Old Jul 8, 2014 | 07:27 AM
  #17
TimmyTim's Avatar
Manufacturers like Toyota have there own brand injector cleaners that you can buy! But I guess that these are not made by Toyota, but another company for them. I use the 2T oil to help lube the fuel pump! I have noticed a difference in the engine idle note! Niw some might say... I'm hearing things! But as I was a pro classical musician working with most of the London based orchestra! I know what I hear... I read about this 2T oil for years on different forums b4 giving it a go! I all I can say us I like the results...I've used Millers oil additives over 15 years! And near enough every other one! Including Slick50 (PTFE, Teflon) That knacker my 1976 Escort! But that was way b4 I knew that Dupont never intended it to be used in the automotive industry!...
There will always be a good debate on the pros and cons of additives! But its up to the end user to see if they work or not. I think that BG244 and Archoil products work to clean and lube fuel systems... and that 2T oil does most of tge same, but at a fraction of the cost. ?.
Old Jul 8, 2014 | 07:44 AM
  #18
Vmaxxer's Avatar
I'm a sceptical cynic by nature so I keep digging for scientific evidence and post it as soon as I find it.
Funny you mention Slick50 because this discussion made me think of that. I knew many people who (in those days) almost religiously promoted the stuff and some of them destroyed their engine with it in a later stage. I was so stupid to use it in my wet sump clutch motorbike and had a hard time restoring he bike to its former condition
Old Jul 8, 2014 | 09:40 AM
  #19
Leedsman's Avatar
Slick-50 I remember from the 1980s. It's a PTFE solution. The other was Molyslip, originally molybdenum disulphide, later with colloidal graphite added.
Ford tried plating the bores experimentally in one of their engines with PTFE in an attempt to reduce friction between pistons-rings and bores, which accounts for some 70% of engine friction It didn't work, as the PTFE coating wore off too quickly -- notice how quickly PTFE is worn off a saucepan? With pistons oscillating up and down thousands of times a minute, Ford's conclusions didn't surprize me.
Jaguar use "compacted-graphited-iron" (CGI) blocks in their engines now, this will prob. be for weight-saving. But there maybe some lubrication advantage from the graphite. Check it out if you like.
In the 1960s, Mobil fitted a Triumph Herald with radio-active piston rings, and then entered it in the "Mobil Economy Run". The car was fitted with sophisticated Geiger-counters. They checked radio-activity in the engine oil sump all the time from start-with-engine-cold. (Hunting for radio-active wear particles). This proper scientific procedure indicated that over 85% of engine wear happened in the warm up period, according to the radio-activity reading from the oil sump. My tests reveal that my own engine is more thirsty below about 60*C (2.8ltr. diesel), using the instant computed readout as a check over very familiar routes, and my own cyl. head temp gauge fitted as an extra to the vehicle's own coolant temp. gauge. Therefore you won't get the best economy from your engine until you get the engine over three-quarters hot. Diesels are partic. prone to poor cold-engine economy as diesel men have found during very cold winters! The high compression of diesel engines (around 18:1) must account for this. The boffins say that below 0*C., engine friction can be SEVEN times usual at cold-start.
Leedsman.
Old Jul 8, 2014 | 10:37 AM
  #20
TimmyTim's Avatar
The Ford Capri Laser model had PTFE in there gearbox from factory! I remember it well as I had the 2.8 monster with the twitchy ****! When you look at 2T oil in diesel you have to think that its an oil like diesel is, although not a heavy oil! So it mixes in straight away with the derv and burns cleaner than diesel. Also the amount you put in is very small compared to the volume of diesel in youf tank.
tylersheehy
Sep 8, 2012 11:25 PM
Scotsman4th
22
Jan 14, 2012 04:55 PM
Scotsman4th
Mar 25, 2011 02:50 PM
Dragcurve
Mar 23, 2011 04:04 AM
Scotsman4th
Mar 22, 2011 07:10 PM
