door handle
Old Jul 7, 2014 | 08:12 PM
mark terpstra's Avatar
Default door handle
08 town and country drivers sliding door **** broke outside. where is a good price, and any video on how to change it out?
thanks mark
Old Jul 10, 2014 | 06:27 PM
pete@co.uk's Avatar
Hi There
Ive had this problem in the past you start by taking off the upper plastic trim around the door it just pulls off then there is a small screw in the top of panel remove that it sits inside what looks like an ashtray then just very carefully pull the panel from the door once off there is a rubber weather shield carefully pull that away look inside then you will see the rear of the door handle you will find 2 nuts you will have to remove the operating rod from the the inside of the handle then remove the 2 nuts its a little awkward to get at the nuts but if i remember rightly one can be accessed through a small hole in the door you will see when you get the panel off its quite easy to do
i cant find any videos for you on changing the handle but ive found a few on getting the panel off
Here,s one about removing replacing the rear door actuator which is not what you want but it shows how to get the door panel off he mentions a metal bracket the nuts are behind that
after the panel is off its pretty self explanatory
hope that helps you
regards
pete......
Old Jul 10, 2014 | 07:43 PM
well thanks pete!
mark
Old Jul 11, 2014 | 06:13 AM
pete@co.uk's Avatar
your very welcome Mark that,s what the forum is all about
Pete..........
parrym
Jun 27, 2011 02:02 PM
rastoma
Mar 17, 2011 10:29 AM
ocaptainjr2
Aug 14, 2007 04:13 PM
01sebringphanatic
Apr 18, 2007 11:30 PM
Cori55
Apr 18, 2006 08:44 PM
