door wiring question
Old Apr 13, 2018 | 02:54 PM
notsofast's Avatar
Default door wiring question
2010 Town and Country Touring. The door lock buttons weren't working on the driver's door panel so I pulled the switch assembly out. I see that I can't pull the switch apart to try to clean the switch and I also saw a 2-prong, female plug unattached behind the door panel. It had a purple wire and a purple and wht or purple and pink wire. I don't see where it would attach and I don't see these 2 wires mentioned together in the wiring schematic.
All door ajar sensors are operating and door safety lights are working. Any ideas?
Old Apr 14, 2018 | 12:30 AM
BiliTheAxe's Avatar
Could be a bad switch. if you can figure out which wire is positive, and which the locks / unlocks the door, you could jumper them and see if the lock works
If that works, then it is definitely a bad switch.
I had the same issue with one of my dads Cadillacs from hell, a Cadillac Cimarron, the eighth worst car ever built.
A car so bad, it almost put Cadillac out of business.
Old Apr 14, 2018 | 10:53 AM
notsofast's Avatar
It's odd because with the switch panel operating all 4 windows, the mirrors and the door locks there are only 3 wires going to it in a single plug. How can only 3 wires operate all that? When I found the 2 purple wires with a plug laying in the door panel I thought for sure it was for this switch panel but it's not.
Old Apr 14, 2018 | 12:13 PM
BiliTheAxe's Avatar
Actually, thinking about it, the two different vehicles are very different.
With yours, the computer controls pretty much everything, so what I said before, will not work with yours.
Try disconnecting the battery for about ten minutes and give the switch another try.
goggs
31
Aug 1, 2017 04:04 PM
Koolcbody
Sep 2, 2015 07:33 PM
Jwrbloom
Oct 15, 2013 03:46 PM
MKOTLAREK
Dec 20, 2012 08:29 AM
andy P
Feb 13, 2012 02:09 AM
