drivers seat moves on it's own
Old Feb 17, 2014 | 02:18 AM
shoosie01's Avatar
Default drivers seat moves on it's own
Hi everyone!
i have a 2009 chrysler grand voyager limited with a problem with the drivers seat
when you open the door slowly the seat moves backwards and forwards repeatedly several times until you either shut or fully open the door
the mechanic has replaced the drivers seat module but still no luck
any ideas?
any help would be very greatly appreciated!!!
Old Feb 17, 2014 | 03:36 AM
Leedsman's Avatar
I had the same "mad seat" syndrome on the Jag. Turned out it was deliberate. It was a program option presumably for old people who had difficulty in getting in and out of the vehicle. Worth looking into on a Chrysler?
Leedsman.
Old Feb 17, 2014 | 05:52 AM
shoosie01's Avatar
thankyou so much for taking the time to get back to me.
I don't think this is a deliberate function - I know the voyager has the easy exit feature but the seat is only supposed to move back once when you are entering or exiting the vehicle, mine jiggles back and forth repeatedly...
makes getting in a bit of a trick - although it does eventually stop if you open the door fully!
thanks again anyway!!
Old Feb 17, 2014 | 09:41 AM
Leedsman's Avatar
There's one other thing you can try for nix. Do a hard reset on all the micros by disconnecting the battery -ve for a few minutes. On here some have said they lose the radio code by doing this, some say not. You may get lucky and clear the fault, with no pain in the wallet.
Leedsman.
Old Feb 17, 2014 | 11:38 AM
Code : It might on the new shape 09 with sat-nav, it has a different security system.
Old Feb 18, 2014 | 01:23 AM
shoosie01's Avatar
thanks everyone!
the problem seems to stop when I deactivate the memory seats
but how do I fix it without leaving the memory seat deactivated?
Old Jun 30, 2015 | 03:08 AM
shoosie01's Avatar
Cool
Hi again!
just thought I'd let you know in case someone else has this problem that it was a partially severed wire in the drivers door...
only took a few days and a module replacement for them to work it out...
thanks to everyone for their help
cheers
Old Jun 30, 2015 | 08:50 AM
tfb's Avatar
tfb
glad you got it sorted
Regards
Richard
Msnatv
Feb 19, 2016 09:30 AM
base300_year2007
Nov 10, 2013 08:24 PM
Chrysler Forum Editor
Apr 16, 2013 02:58 PM
jimhild
Jan 27, 2008 11:24 PM
