EGR
My '97 T&C's check engine light recently came on, and the trouble code was (I didn't write down the number) EGR low emission. I replaced the EGR valve, and still have the same problem. Are there any sensors that work with the egr valve? Any help would be appreciated.
Mileage?
Symptoms, anything like that would be helpful....
[ol][*]Remove EGR tube attaching bolts from intake and exhaust manifolds.[*]Clean intake and exhaust manifold gasket surfaces. Discard old gasket.[*]Check for signs of leakage or cracked surfaces on either manifolds or tube. Repair or replace as necessary[/ol]
Check your lines, EGR Solenoid connections, and wiring.....
