Fitting a second thermostat...
Old Nov 30, 2015 | 04:00 PM
  #61
Andrips's Avatar
Vmaxxer, unfortunately I don't have access to that image.
Old Nov 30, 2015 | 05:25 PM
  #62
Old Dec 1, 2015 | 01:05 PM
  #63
Vmaxxer's Avatar
Or post some responses here and there, you need some postcount to get access I believe..
Old Dec 6, 2015 | 09:09 AM
  #64
Andrips's Avatar
Thanks Vmaxxer and QinteQ, I finally got access.
I fitted the second stat, but my biggest issue is how to get the air out of the system?
Antifreeze level is very high and I still have left over. I tried to squeeze the pipe, but it does not help.
Update: 20 min small trip around the town and level is back to normal. Thanks to Vmaxxer.
Old Dec 6, 2015 | 11:49 AM
  #65
Vmaxxer's Avatar
If the hole in your thermostat is sufficient any airlock would disappear after some driving. Just check the level after some kilometers driving and keep an eye on your thermometer.
Old Dec 6, 2015 | 11:53 AM
  #66
Andrips's Avatar
Thanks, mate.
I drilled a small 1.5 mm hole, should be fine. Ok, will do a small trip and have a look again.
Will post some photos tomorrow of fitting process.
Old Dec 6, 2015 | 12:32 PM
  #67
Andrips's Avatar
Thanks Vmaxxer,
20 min trip around the town and level back to normal. Will keep eye on the level for next few days.
Now must find how to sort out he webasto issue.
Old Dec 6, 2015 | 02:41 PM
  #68
Set the L&R digital temp & fan to whatever you want then set the heating to auto. The next time you switch on in the morning it should just work, if the x3 vertical arrows are lit on the info-bar it means its functioning, if its not tell the group what's not working.
Old Dec 6, 2015 | 02:55 PM
  #69
Andrips's Avatar
never had these arrows on my panel. but I can hear that heater is running, noise comes from underneath
Old Dec 6, 2015 | 03:47 PM
  #70
darkcild101's Avatar
Thanks, mate.
Thanks in advance for photos of fitting process
Its the Renault 5 thermostat, correct? Going for £3.99 on ebay just now
