Fitting a second thermostat - the guide!
Old Oct 19, 2016 | 08:48 AM
andyb2000's Avatar
Thumbs up Fitting a second thermostat - the guide!
Hi folks,
This weekend I decided to follow Leedsman's great idea/guide on fitting the second thermostat to my 2005 GV and it works great!
(See original thread here https://www.chryslerforum.com/forum/...rmostat-20480/
I did a how-to video on it too so if you want to give it a go, it's a nice and easy one to do:
Thanks once again to Leedsman for this solution!
Old Oct 19, 2016 | 01:37 PM
Thanks Andy, brilliant video and a great help to us all. My 2.8 is warming up OK at the moment but you make the job look so easy in your great tutorial that I think I'll add another thermostat before the winter sets in.
Alan
Old Oct 19, 2016 | 02:56 PM
I found an article where this mod works on the Rover 75 as well.
Old Apr 3, 2017 | 02:26 PM
Scottd2424's Avatar
Fantastic, carried out this mod this evening - quick and easy fix thank you.
Yay!
Scott
Old Apr 3, 2017 | 03:50 PM
I'm a consensual objector and happy with the real thermostat at back of engine that was fitted by my son nearly 5 years ago, with my direction of course. Son said he wouldn't go near my car again after that job due to the heated argument he had with it. But he calmed down quickly after white coats from the Looney House turned up. Got a real mechanic on the job now though..
But in all a really good idea to fit the thermostat in this place and I'm sure the dialogue will be in different languages by now.
Old Apr 4, 2017 | 02:11 PM
Vmaxxer's Avatar
I used this brilliant thermostat modification about 50.000 km ago and my temperature is still perfect.
happy happy joy joy
Old Oct 29, 2020 | 02:26 AM
RodgerA's Avatar
Hi,
Does anybody know the Renault model/part number for this thermostat, it seems to be a good fit.
Old Oct 29, 2020 | 04:40 AM
It was in the post that AndyB linked to and kindly provided by QinteQ https://www.micksgarage.com/search?k...26575&pk=8ca9a
Old Jul 11, 2024 | 07:53 PM
Joakes's Avatar
Thanks for the great video. I have a 2012 Grand Voyager 2.8 CRD with the same problem. The cooling system configuration is different though. See below. Does it matter where the second thermostat goes? I am assuming that the 1.5mm hole will allow enough flow so that the thermostat will open, but don't want to assume myself into a cooked engine. Cheers. Joakes from Aus.
Pipe on this model is lower than in the video.
Hose connecting directly to the top of the radiator is easier to access and I would have to drain less fluid. Would it be OK to put the thermostat here?
Old Jul 11, 2024 | 07:57 PM
Joakes's Avatar
By the way. I took the Chyrsler to a dealership service centre in Bendigo and the quote to replace the thermostat is attached.
I know they replace the whole water pump assembly, but my eyes popped at the $2998.92 quote.
