front end squeek when pushing down on hood
Old Oct 21, 2015 | 03:33 PM
nickstoyz's Avatar
Default front end squeek when pushing down on hood
2003 T&C. So I have this squeaking kinda sound going on, kinda like an old metal bed frame squeaks when your doing the nasty on it lol . It happens when driving but also I can make it squeak when parked by pushing down on the front end bouncing it. I can't narrow it down, sounds like the struts but could it be some other bushing? Sway bar bushings were replaced last spring for the knocking didn't cure the squeaking. Any clue?
Old Oct 22, 2015 | 01:44 PM
I'll go for sway bar Bushings/rubbers. Sounds like rubber on metal. Was going to say to squirt some lubricant on them but which to choose that won't deteriorate the rubber.
Heard of strut top mounts/bearings squeaking as well but only on turning.
Old Oct 22, 2015 | 04:32 PM
Squirt some soapy water on the joints/bushing one at a time and see if the squeak goes away. Soapy water won't hurt anything.
Old Oct 23, 2015 | 12:17 PM
Think the answer is Silicon spray. But saying that I don't think the rubber bushings for the anti-roll bar should act as a bearing or they would wear away quite rapidly. The bushings/rubbers are there to grip the bar and as the bar turns the rubber flexes.
That is why the rubbers should be fitted and secured with the wheels on the ground.
Old Nov 4, 2015 | 04:33 PM
nickstoyz's Avatar
well I sprayed silicone spray and it still squeaks, creeks whatever u wanna cal it. I'm going to have to get the vans front end up so I can get under it while someone gently bounces the front end.
Old Nov 13, 2015 | 12:51 PM
msd26129's Avatar
Top mount ... Had this on mine .
lamaradams
Jun 19, 2014 09:37 AM
peterious
Dec 6, 2013 10:31 AM
teddysmith1952
Dec 3, 2011 08:59 PM
ponch37300
Jul 29, 2009 07:54 PM
DR4x4Hemi
Feb 5, 2009 07:30 PM
