Front wheel bearing/hub.
Old May 28, 2014 | 04:03 AM
  #21
Leedsman's Avatar
Squirt some graphite grease into the wheel bearing and see if the noise diminishes a lot. If it does, the wheel-bearing will be worn out. Your steering arm could be a second wear problem -- sod's law!
Leedsman.
Old May 28, 2014 | 05:40 PM
  #22
sundowners's Avatar
Originally Posted by pob
Ok. After last weekends non event I soaked the joints in diesel and left them, so I went out and had another look.
The car has all the symptoms of a wheel bearing on the way out, general hum when driving and increases on the front right when turning left car wandered over the road. But when I took the wheel off hub nut off and pulled the drive shaft back the bearing seemed tight.------------------- nothing wrong with the bearing?
Hi
I could detect NO PLAY in my wheel bearing------but noise stopped when replaced
Nigel
Old May 29, 2014 | 03:41 AM
  #23
Leedsman's Avatar
Not looked into this partic. arrangement, but if it's a conventional taper-roller bearing with a castle nut and split-pin adjustment, you can take out the play all right, but the race can still be badly scored and therefore noisy. The same could apply to a plain ball bearing one might suppose. Good lesson for all here, replacement is only way to find out what's noisy.
Leedsman.
Old May 30, 2014 | 04:47 PM
  #24
sundowners's Avatar
Leedsman.
Hi
The thing with an old taper bearing------you can take it apart an look at it -------all sooo easy
Nigel
Bojib
Apr 11, 2015 11:28 AM
travelmad
Aug 28, 2013 04:36 PM
mrmoleswood
Apr 28, 2012 05:42 AM
Vasiliki-Greece
Jun 12, 2009 06:34 AM
gareth111278
Nov 22, 2008 06:39 AM
