Fuel filter
Old May 29, 2011 | 03:30 PM
barracuda96's Avatar
Default Fuel filter
I have an 03 Town & Country 3.3L. I need to replace the fuel filter. Can anyone tell me the best way relieve the pressure from the system. I don't want to get sprayed with gas today.
Old May 29, 2011 | 11:13 PM
andyr78's Avatar
I actually just looked this up today. The unfortunate part is it sounds like you need to drop the gas tank to do this job.
Remove the fuel pump relay from the Power Distribution Center (PDC). Start the vehicle until it stalls. Try and start the vehicle several times to verify the system is fully relieved. Reinstall the relay once all repair procedures have been completed
Old May 30, 2011 | 05:23 AM
Thank you for the help. The job is done and I have to say it was not that hard at all. I used a piece of 2 x 6 long enough to cover both tank straps and a floor jack. I only had to lower the tank on one side about eight inches to remove the one 10mm bolt and fuel lines. Removing the fuel relay and cranking the vehicle several times works great. Still had some fuel in the line but no pressure. Thank you again.
Carlo60
Apr 7, 2011 03:45 PM
monbenkey
Dec 29, 2007 05:52 PM
weinerschizel
Nov 26, 2007 02:53 PM
safetyman
May 25, 2006 05:43 PM
stumped
Jun 21, 2005 11:23 PM
