Fuel pump replacement '96 Voyager 3.3
Old Oct 7, 2009 | 06:42 AM
Master Chief's Avatar
Originally Posted by 22chrysler
pinched line, fuel filter and 2 things that come to mind for this problem.
We'll lower the thank later today, to check the line, but what I know is that we replaced the fuel filter on the pump (in the thank) and now I wonder if there's another one. If yes where?
Thank you for your assistance!
Old Oct 7, 2009 | 07:16 PM
22chrysler's Avatar
follow the fuel lines from the tank along the frame. the filter in the tank is known as a sock, it just prevents really big stuff from getting in. an i assume you used a brand new pump as a complete assembly?
Old Oct 8, 2009 | 01:40 PM
Just the fuel pump. I mean the motor inside the unit. Came with a new filter.
Old Oct 8, 2009 | 03:21 PM
22chrysler's Avatar
hopefully it is the correct pressure pump for that vehicle. i've seen where the wrong pump was put in the box. old vans 1988-1990 used 15psi on 2.5 efi. do you have a quality fuel pressure guage set with adapters? i do and i would "T" into the fuel line near the pump to see what pressures are.
but in my case, if I had a bad part, i'd just toss in a good used one (but then I have 12 of these vans in my parts inventory)
Old Oct 11, 2009 | 05:17 AM
  #15
We'll lower the tank next week, and will remove the pump if the pressure keeps sucking. Thanks for the tips!
Darth Menace
Feb 19, 2016 09:16 PM
1997DodgeGrandCaravanES
Jul 21, 2014 04:50 PM
Cirrus & Breeze
Jul 17, 2014 01:40 PM
Jul 17, 2014 01:39 PM
Jul 17, 2014 01:25 PM
