Fuse Panel
Old Sep 17, 2017 | 12:53 PM
Cerebro's Avatar
The front wipers of my 2012 Chrysler T&C are not turning off, even when I disconnect the multifunction switch. The only way to make it to stop is turning the car off or taking the fuse off.
I'm trying to locate the wiper relay, since it is not in the underhood fuse box. Anyone knows where I can find the wiper relay?
Old Sep 21, 2017 | 12:57 PM
Raptor 07's Avatar
There are two in the TIPM labeled wiper high/low relay and wiper on/off relay. Locations are identified on the underside of the TIPM lid. Swap them and see if something changes. Disconnect negative battery cable for a few minutes to reset the data bus.
Old Sep 25, 2017 | 04:15 PM
Cerebro's Avatar
Thanks for trying to help Raptor 07, but definitely there are no wiper relay in the underhood fuse box. I had already checked every single relays there and none of them are for wiper. The TIPM lid shows any wiper relay... there is only wiper fuse there.
Old Sep 25, 2017 | 05:38 PM
REBEL59's Avatar
PLEASE do the part 2 of Raptor 7's post, Disconnect the NEG. cable for a few MINUTES to reset the BCM?and TIPM. You are correct that there is no actual plug in relay..It is hard wired into the TIPM and controlled with the BCM.
nitehwk
Mar 1, 2014 06:49 AM
acat29
Other
Mar 1, 2013 11:16 PM
birdshelly10
Apr 16, 2011 03:34 PM
SlowBoy318
Aug 26, 2010 09:27 AM
InstantNoodles
Sep 23, 2009 03:27 PM
