2000 town & country 3.3 lt
engine light on, transmission slips. checked with a hand held digital diagnostic tool. codes are po7030 gear 4 incorrect ratio and po7032 gear 2 incorrect ratio. also p1781, p1782, p1784 and po700. what do i do now?
2000 town & country 3.3 L.
code p0734 gear 4 incorrect ratio, p0732 gear 2 incorrect ratio, p1781 pressure switch circuit 0D, p1782 pressure switch circuit 2-4, p1784 pressure switch circuit LR, p0700 transmission control system MIL request.
what do i need to do with this problem ?
If you don't get an answer here head over to DodgeForum.com or The Chrysler Minivan Fan Club . There are several tranny techs on the forums.
The whizzing is usually indicative of torque converter malfunction from loss of fluid pressure. It means a rebuild....probably. First thing I would (that you can do yourself) is drop the pan and see if there is any metal in there. Then you will have no doubt.
Eirelin
05-18-2012 07:09 AM
2000 T&C
05-01-2012 12:49 PM
Baronesa
08-22-2011 11:09 PM
DRFUZZ
01-06-2010 10:19 AM
