Grand Voyager Air Con
Old Oct 15, 2012 | 07:43 AM
mark0530's Avatar
Default Grand Voyager Air Con
The AC compressor has come away from the engine, it has damaged the chain housing and can not be reattached. can i remove the AC and install a new drive belt to run the other parts. the one i have tried would not run the water pump ??
Old Oct 28, 2012 | 04:56 PM
deanne's Avatar
Yes you can however we left the ac compresser in and just by passed it. My wife ac clutch went and at the price of the new one £400+ thought better off it. Its not an off the shelf belt you need (europarts, unipart can get them) i cant rember the size 122.5 or something, we ended up getting one trying it, popping back for another size to nail it down.
The belt runs close circa 10mm to itself so watch for wear/stretching as the tensioner will push it towards itself, but at £26 + fitting (neighbour did mine) it was a cheaper alternative. Heater still works and just ambient cold. If we keep the car next year may look for a secondhand ac unit.
If you do bypass this it will take probably a days work as you will need to try 5-6 belts to find the one you want, and possibly order it (next morning)
To fit and get back in the road about 1/2 hour.
good luck
Jason1969
Jul 8, 2013 09:35 PM
sean81
Sep 10, 2010 06:50 AM
tintin
Jul 11, 2010 05:29 AM
redbryn
9
Aug 10, 2008 02:48 PM
gareth111278
Aug 4, 2008 01:16 PM
