help please
Old May 5, 2020 | 06:10 AM
sturuss's Avatar
Unhappy help please
hi got bit of a head scratcher here
i have a 2003 3.3 v6 grand voyager and every time i park in sloped driveway my power sliding doors work as they should
the problem is when out driving on level ground they will not open just makes that noise as it the motor is stuck have changed motor in doors
on both sides checked for broken wires they ok so now it doing my head in pls help tia
Old May 5, 2020 | 06:37 AM
REBEL59's Avatar
Can't say this will fix the problem, BUT...
From your posting of works on a slope and not on level surface.....
Have you tried lubricating the sliding door pivot link (the middle of the three door roller tracks? They can get "sticky" and overcome the preset safety action.limiter.
Old May 5, 2020 | 06:46 AM
"when out driving on level ground they will not open"
They won't [design] open while driving.
Old May 5, 2020 | 06:53 AM
sturuss's Avatar
LOL dont try when driving im on about when stopped and on level ground and passengers need to exit from car and doors not work
checked wiring no breaks tracks greased had new motors for doors both sides
Old May 5, 2020 | 08:33 AM
REBEL59's Avatar
I did NOT mean the tracks. I said the pivot link hinge for the center track roller. Also a "safety" function is the van needs to be in PARK for doors to operate.
Last thought is one of the release cables is slightly out of adjustment from replacing the motors.
Old May 5, 2020 | 11:17 AM
sturuss's Avatar
yep everthing is ok with rollers
motors fine no release cables connected to motors only power and drive connector to sprocket
Old May 5, 2020 | 02:17 PM
2003 3.3 v6
I'm year 2005 CRD 2..8 MkIV so cant speak to your motor. Electrical, Mechanical Logic. I'm electromagnetically managed. Door tracks are stepper motors [12v] controlled by [PCi logic] BUS. You tell it to open door it sends an instruction to apply voltage to that stepper via BCM through IPM. Low/poor starter battery power often causes error code in BCM and logic fails.
Detach + battery terminal 20 minutes then reattach clears short [not long] codes but enough to make door switch operate again. You had battery / starting issues ? Been messing with electrics ? Aftermarket radio ? BTW my radio codes are stored in BCM I've no idea on yours so caveat emptor my friend.
JaSonic
Mar 2, 2022 11:43 PM
sturuss
May 4, 2020 07:13 PM
link33
Jan 8, 2008 07:46 PM
mhfry1
Dec 17, 2007 07:19 AM
firebiz16
Mar 1, 2006 07:52 PM
