HELP Town & Country wont start 3.8l
Old Nov 6, 2015 | 01:20 PM
tfb's Avatar
tfb
I'm not as familiar with petrols, but...
check you have compression
can you remove an injector from the head and check if fuel is being sprayed out?
I know you said you had spark, but I'd like to see a spark plug out and the spark on the plug.
not sure how you would check ignition timing on a modern petrol, I liked points and a distributor...you could see what was going on.
Richard
Old Nov 6, 2015 | 06:33 PM
pheel85's Avatar
Im getting compression. when it turns over i open the throttle and can hear the compression happening. I have to check to see if the fuel injectors are spraying. I assume they are as i watch the fuel pressure relieve pretty quick. I also installed a inline spark checker and it lit up. Like i said no lights came on and none have come on since. Im really thinking it jumped timing. It has 248,000 miles and Im sure the other owner didnt have it serviced. Im just about done with it.
Old Nov 7, 2015 | 12:05 PM
Regarding immobiliser, does the light for this go out on keying ignition. I'm not sure if pump still runs in this case.
Old Nov 7, 2015 | 12:08 PM
You've not got toasted wires near exhast pipes I hope as that was last week.
Old Nov 10, 2015 | 04:46 PM
  #15
U dont have a MAF on gas Chrysler a tps wont stop u from starting just idle issue. how are you checking for spark and still codes in the computer?
Old Nov 11, 2015 | 05:14 PM
  #16
pheel85's Avatar
No codes in the computer and I have a inline spark plug tester. If it has spark it lights up. I have figured it out. My timing chain jumped like I thought. It has 247,000 and I believe it has the nylon gears for the timing chain. From what I saw it is worn out and so am I. I have put it up for sale, someone else can deal with it. I have invested to much time and money into it.
Eddie A. Steiner
14
Aug 7, 2015 03:10 PM
mark_gober
14
Aug 19, 2012 10:22 AM
crash1972
Jun 14, 2011 10:15 AM
ekhealy
May 23, 2011 10:47 PM
lilbo90
Sep 19, 2010 07:54 AM
