Hesitation and Backfire, No codes
Old Jun 8, 2013 | 11:56 AM
jsb1964's Avatar
Default Hesitation and Backfire, No codes
Hello all! I have a 2001 T&C (3.3) that idles fine but hesitates and backfires on acceleration. I have used fuel injector cleaner and fuel system de-icer. My air cleaner is practically new. I am getting no codes at all. I did have a battery light for a brief time the other day. Would a dying battery cause my problems? Any other ideas would be appreciated. Thanks!
Old Jun 8, 2013 | 02:20 PM
Raptor 07's Avatar
Battery? Could be. Backfire out the intake? It's running lean. Try checking fuel pressure. Should see 55 psi. You can sign out a gauge from most parts stores but you'll need adapters to connect it if there's not a test port on the fuel rail.
Old Jun 17, 2013 | 03:26 PM
jimmyybob's Avatar
This is exactly what mine did, read the saga here.
https://www.chryslerforum.com/forum/...exhaust-18053/
With the engine running reach around the back and give the wiring a bit of a pull and tug and see if it suddenly runs bad.
davet
Jul 3, 2021 06:58 PM
Jfizzle
Feb 22, 2020 04:37 PM
jfyfe
Aug 18, 2010 07:43 PM
robbiedog
Jul 19, 2010 10:00 AM
adrake
Jul 19, 2007 05:31 PM
