How to replace the Serpentine belt on a 2005 T&C?
Old Feb 24, 2011 | 02:21 PM
bowlingss's Avatar
Default How to replace the Serpentine belt on a 2005 T&C?
How do you replace the Serpentine belt on a 2005 T&C? Our has over 100K and has not been replaced. I changed one long time ago on our old 94 Voy Van but was hoping it would be easier on this one.
Anyone have a write up?
Thanks.
Bill
Old Feb 24, 2011 | 10:03 PM
sapp4l's Avatar
Old Feb 25, 2011 | 09:13 AM
bowlingss's Avatar
Originally Posted by sapp4l
Thanks. Is the 2202 Caravan the same as a 2005 T&C?
Bill
Old Feb 25, 2011 | 09:27 AM
01 to 07 are the same so long as the engine size is the same
Old Feb 25, 2011 | 07:47 PM
bowlingss's Avatar
Originally Posted by bowlingss
Thanks. Is the 2002 Caravan the same as a 2005 T&C?
Bill
Should I replace the idler and pulley?
Bill
Old Feb 25, 2011 | 07:48 PM
bowlingss's Avatar
Bill
Old Feb 26, 2011 | 05:38 AM
is it bad?
Old Feb 27, 2011 | 11:26 AM
sapp4l's Avatar
I'd replace the idler and tensioner. Not much $$, and a pain to do it later if you need to. Easier to get all the parts at one time, do it right, and move on. Tensioners get noisy after a while, and the idlers seem to go without warning (at least for me). For 30 or 40 for the tensioner, and 10-15 for the idler, isn't worth fooling with.
Old Feb 27, 2011 | 06:13 PM
bowlingss's Avatar
The belt does not look that bad. After taking the guard off I found I need a special tool to remove the tension off the belt. The tensioner has a 1/2" hole in it but it is so close to the frame that I can not get a 1/2" racket in there. Do they make a special tool or do I need to make one? I might just change the pulleys once I have the right tools.
Thanks.
Bill
Old Mar 1, 2011 | 10:02 AM
bowlingss's Avatar
Thanks.
Bill
I found a tool from Auto Zone. I have not picked it up yet. I hope it will work.
Thanks for every ones help.
Bill
