Hydraulic valve lifter 2005 3.3l
Old Jun 27, 2016 | 08:24 PM
thegrandvoyager2's Avatar
Default Hydraulic valve lifter 2005 3.3l
hi members,
my 2005 Grand Voyager seems to have a faulty/collapsed valve lifter.
Can I get to it by removing the inlet manifold and leaving the heads in place?
Any advice would be appreciated.
I have tried flushing the motor with a Qt of ATF in the crankcase but this has not helped.
Old Jun 27, 2016 | 10:24 PM
a lifter moves a rocker arm and in turns pushes the valve so the rocker arm has to be removed o get a lifter out.
Old Jun 27, 2016 | 10:57 PM
thanks Chrysler Tech,
So, off with the rocker arm and out with the pushrods and I should be able to hook the valve lifter and lift it up and out thru the pushrod hole in the head?
Old Jun 28, 2016 | 12:36 PM
Never mind scratch that the 05 has it that u must take the heads off to get to the lifters there is a plate holding them down and the heads haft to come off first.
Old Jun 28, 2016 | 05:23 PM
Thanks for the clarification Chrysler Tech
marty1966
Apr 2, 2018 04:32 PM
stmiller96
May 22, 2012 08:43 AM
yaseling
Jun 8, 2011 12:13 PM
RobertMunn
Jul 24, 2010 12:07 AM
Mar 11, 2006 12:10 AM
