Identifying 30a fuse on 2005 grand voyager crd
Old Jul 22, 2014 | 09:05 AM
Seggelke's Avatar
Default Identifying 30a fuse on 2005 grand voyager crd
I have a blown 30 amp fuse hanging off the plus pole of the battery. It has burned pretty badly - the fuseholder has been blistered and the insulatio on one wire is melted.
I have no idea what this blown fuse is for.
Old Jul 22, 2014 | 11:29 AM
How about tracing wire back to sourse. Is the wire bound in with the rest or standing alone. Just wondering if its a connection for Taxi appliences and the disconnected wire has earthed.
Old Jul 22, 2014 | 01:31 PM
Seggelke's Avatar
I was hoping to avoid tracing the wire as it could go anywhere - hence my post.
FWIW it is a green 30amp fuse.
Old Jul 22, 2014 | 01:34 PM
tfb's Avatar
tfb
what colour is/was the wiring either side?, can you post a picture?
Regards
Richard
Old Jul 22, 2014 | 01:47 PM
Leedsman's Avatar
You need to be very careful about "buckshee" wiring direct from a battery + terminal. No proper auto-electrician would ever do this as a fault could result in a fire destroying the vehicle. Insurance investigators would discover any buckshee wiring and possibly refuse to pay out. Fortunately the amateur electrician has at least put a fuse in circuit.
You should for your own peace of mind FULLY investigate ALL this wiring, and probably remove it. Getting an electric shock is impossible from a 12volt circuit, but starting a fire in a 12volt starter-battery circuit is very possible.
I speak as one who has lost a car (write-off) from this factor. It was a Citroen C4 and caused by the ABS unit under the bonnet/hood. Fault in that case was the manufacturer.
Leedsman.
Old Jul 22, 2014 | 03:04 PM
Seggelke's Avatar
Thanks all, here are two pictures
<iframe width="480" height="360" src="http://s1286.photobucket.com/user/se...how/"></iframe>
Old Jul 22, 2014 | 03:07 PM
Seggelke's Avatar
That did not go well. Are new members not allowed to edit posts or post pictures?
Trying again:
seggelke's Library | Photobucket
Old Jul 22, 2014 | 03:11 PM
tfb's Avatar
tfb
Hmm..that's not standard by any means. Remove the wire from the battery terminal to prevent any further chance of a short.
To find out what it was added for you'll have to hand trace the wire or find something that isn't working anymore.
Regards
Richard
Old Jul 22, 2014 | 03:40 PM
Seggelke's Avatar
Thanks, the only thing I am aware of that is not working is the AC cooling.
I was hoping I could just snip the wires and replace the fuse and fuseholder, but I think I will follow your advice, Richard, and disconnect it entirely. Quite the puzzle - fuse blown like no other yet pretty much everything works fine.
VJoseph
May 10, 2022 07:16 AM
skylindrftr
Jun 20, 2011 02:31 AM
ChryslerNightmare
May 7, 2011 02:14 AM
ManuteSwol
Aug 23, 2010 06:42 AM
sentientmachine
Apr 14, 2010 11:34 AM
