Idle dies and/or surges
Old May 19, 2010 | 10:04 PM
loghog74's Avatar
Default P0505 Idle Air Control Sysem Malfunction
If there is a code set for the idle air control motor it will be P0505 but don't assume that it means the valve/motor is bad. It could be a bad wire or several other things I'm sure. The Haynes repair manual says you can test the IAC by disconnecting the plug and listening for a change in idle rpm. When I disconnected mine the engine shut off after about 15 seconds. Make sure it is definately faulty before you go buy one. Most parts stores won't let you return an electrical part once installed unless your a certified mechanic. They are about $90.00
Old May 20, 2010 | 08:42 AM
5thvet's Avatar
Loghog,
Thanks for the code and heads up. I haven't had a chance to get down to my son in laws brothers shop becasue I have been traveling but will get there sometime this weekend. I will report back when I do.
Don
Old May 21, 2010 | 08:54 PM
loghog74's Avatar
Yes please do our 98 Town & Country started out doing the exact same thing yours is doing. We let it go for a little while and it progressively got worse until it shut off and left us stranded on the side of the road. It would not crank until the engine cooled down. We brought it to our local mechanic and they have changed the camshaft position sensor, idle air control motor, crankshaft position sensor, a coil pack and the computer and it still isn't fixed. It has been there for a month now. So I don't know if your situation could worsen if not dealt with soon. Let me know the outcome.
aaron1wii
Aug 26, 2014 01:05 PM
mathesar
Jul 6, 2013 09:04 PM
mathesar
Cirrus & Breeze
Aug 6, 2011 12:45 AM
macfarlane300
Feb 2, 2009 09:00 AM
bloom
Mar 2, 2008 04:30 PM
