Ignition Lock Stuck
Old Jan 12, 2014 | 08:05 AM
scottshaw's Avatar
Default Ignition Lock Stuck
01 Chrysler T&C, 116,000 miles. Friday it was fine, Saturday I put the key in the ignition and I cannot turn it at all. Turning the steering wheel to release any tension on the lock, it still won't turn. Tried all 3 keys on it. I assume it's got to be able to turn to even get it out to replace it. Van is stuck in the garage and will have to be dragged out in park and towed to the dealership if I can't do anything with it. Has anyone experienced this before? What did you do?
Thanks!
Old Jan 12, 2014 | 12:09 PM
ball your hand up in a fist use it like a hammer With one hand apple pressure like u were turning the key on with the other had as a fist hit the key like a hammer it will come free then Replace the key cyl and all will be good.
Old Jan 12, 2014 | 01:06 PM
scottshaw's Avatar
Thank you! Worked like a charm. I don't see the traditional little pin hole to put a pin in to release the lock cylinder. Can anyone post that procedure?
Old Jan 12, 2014 | 10:01 PM
remove the steering cover 2 or 3 screws then u will see it facing down key must be in run position to do.
tbird2340
Feb 19, 2020 04:41 AM
jent84
Sep 22, 2012 09:55 AM
pete3000
Jul 19, 2011 08:38 AM
woody79
Jun 11, 2010 09:59 AM
Justme1969
Jun 15, 2007 07:53 PM
