Illuminated Lights
Old May 12, 2015 | 09:25 AM
Dominic26's Avatar
Originally Posted by Vmaxxer
mail with last 2 pics send
Vmaxxer, I'm sorry. I emptied the mailbox in a "delete all" from my phone by accident. Could you please resend (dmscorz@gmail.com)
Old May 12, 2015 | 04:53 PM
Vmaxxer's Avatar
done
Old May 12, 2015 | 08:50 PM
Dominic26's Avatar
Found some more pics.
1 of the backside of the light switch panel (arrow points to foot of bulb holder)
And one of the bulb with arrow pointing to the metal strips you can "unwrap" so you can replace the bulb in the holder.
I will have to pull the headlight switch /mirror control panel out again Wednesday or Thursday. I really do not remember seeing it the first time. Then again, what you sent me is not what I expected. I will let you know what happens
Thank you,
Dominic
Old May 13, 2015 | 02:59 PM
Dominic26's Avatar
If we are talking about this panel the bulbs should look like these (but longer and with a blue tip)
I got it open, but you will NOT believe what I found. No bulbs in there. The headlamp switch enclosure has two sockets and the mirror one. To top it off, the mirror's socket has tape over it with the Chrysler logo imprinted. They never put them in at the factory!! Time to hit a junkyard. It's just so dark in that area of the dash.
Old May 13, 2015 | 05:43 PM
  #15
Vmaxxer's Avatar
Strange...But possible.. I replaced the panel some time ago and found that there are differences in panels off factory.
Some where delivered with headlight adjustment (like in my voyager) and others not. Panels are roughly the same but with various functionality activated.
I soldered an extra pin on my replacement panel so headlight adjuster's worked on my new panel (clever me )
Maybe in your case the panel was delivered without illumination for some obscure reason?
I would indeed get the bulbs from a scrapyard (or even a complete panel)
Old May 14, 2015 | 02:11 AM
  #16
andyb2000's Avatar
If you struggle to get them drop me a message, I just recently got a pack of holders and green led bulbs for my dash illumination that I ended up not needing so I can post you a couple?
Old Nov 23, 2015 | 10:56 AM
  #17
msd26129's Avatar
Originally Posted by andyb2000
Also, the bad news on the heated seats illumination, I had quite a challenge get in doing this on my old gv.
Removing the whole centre console is easy, two screws at top, two hidden under a think grey plastic panel at Base (just above cigarette tray) and then prise the whole fake-oak effect panel from one of the sides, unclip the control cables (push red clip in then press down to release) on mine there were 3.one top, two middle for climate control.
Now the harder part, the heated seat and hazard indicator piece you gently prise out. I used 3 or 4 thin screwdrivers simultaneously in the notches. Keep it flat as when you take it out you need to keep the switches in the right position.
Once out you'll see the problem. Panel illumination is by a set of soldered in bulbs. Who on earth does that!
What I did was de-soldered them and replaced them with 12v leds in their place. Was fiddly soldering but in the end it worked great.
Not sure on your soldering and skill level but might be worth taking a look as getting at them isn't a huge job.
Good luck
what size led did you have to get for this ? any pics
Old Nov 24, 2015 | 04:36 AM
  #18
andyb2000's Avatar
wow, this is an old thread!
The LEDs I used were 2.5mm as they are quite small to fit onto the boards, but the soldering wasn't anything difficult to do.
Old Nov 24, 2015 | 10:58 AM
  #19
msd26129's Avatar
im not to bad at soldering . do you have any pics of the end result ..
richjones19772000
Feb 12, 2014 09:06 AM
fkthomas
Aug 20, 2009 09:50 PM
mikeDMB79
Feb 29, 2008 02:58 PM
bentleybloke
Feb 28, 2008 05:12 AM
F150
Mar 20, 2007 08:27 AM
