intermittant no start
Old Apr 26, 2007 | 03:02 PM
doogstrum's Avatar
Default intermittant no start
I have a 1999 Chrysler T & C van.Sometimes it starts then dies after about 1 second.When this happens the lower row of dash lights don't work including the trip/odometer.The tach doesn't work and the numbers on the info panel on the roof don't come on.Any ideas what is wrong? Doug
Old Apr 26, 2007 | 07:39 PM
Default RE: intermittant no start
humm need some more stuff to go on. Any other lights not work?? are u able to restart the van?? any codes in the pcm? DO u have sercuity from the factory or an aftermarket system?>
Old Apr 27, 2007 | 12:43 AM
doogstrum's Avatar
The top row of lights above the gauges all work and the lights either side of odometer don't.To restart I have to turn the key off then it will start and stall again as long as the lower lights don't come on.Usually have to wait anywhere from 5 minutes to overnight before it works right.It has the factory installed security system.Using the key on / off three times to retrieve codes gave no codes.I haven't had it checked by a DRB II but the check engine light isn't on,but does work when the ignition is turned on.
Old Apr 27, 2007 | 12:51 AM
doogstrum's Avatar
Also add that it has happens at any time.Outside temp hot or cold ,after it's been running or first thing in the morm rain or shine.Plus it has never stopped after it started and is being driven. Any help?
Old Apr 27, 2007 | 01:04 AM
when u are talking about the light son either side of the dash are u talking about the lights that make the cluster visable at night ot all the warning lights? I u say that the night time lights dont work and the other stuff as well I would say its the cluster it self the printed cky board. There are posts on here some where about how to fix the board or atleast give it a shot.
if not need a new ckt board.
Old Apr 27, 2007 | 01:24 AM
doogstrum's Avatar
It's the warning lights that don't work.I think all the illumination lights work. I saw the post about soldering the connections.Maybe I'll give that a try.MANY THANKS for your help.
Old May 5, 2007 | 12:37 AM
doogstrum's Avatar
I have just removed the instrument cluster (tach/speedo/odometer) from the van.The information center still works and it will start up and run.Is the problem in the body control module ? If so where is it located?Since my last post it has acted up only once and I pounded on the top of the dash and it started working fine.Any help is appreciated. Doug
Old May 5, 2007 | 01:05 AM
though u were going to fix the cluster why have u not??? that is your prob either replace it or fix it with the posts found on here about the repair
Jimdec1
Jul 1, 2013 05:47 PM
PTfred33
Oct 29, 2009 07:30 AM
mjhart34
May 7, 2009 04:34 PM
mark44004
May 25, 2008 04:47 PM
doogstrum
May 5, 2007 01:05 AM
