leaking air conditioning unit
Old Jun 29, 2007 | 08:59 AM
pepe's Avatar
Default leaking air conditioning unit
When I run the air conditioning there is water leaking in the floor board of the passenger side. I took the van to the local dealer who told me it needed a new O ring. They kept the van two days and charged $50 to replace the O ring. The problem continues I took the van back and asked them to check the drain line since there seems to be no water draining on the ground after I park. After looking at the van for over an hour they tell me it needs a new "seal" because the old one has deteroiated, the cost will be $700 to replace this seal because they have to completely remove the dash in order to get to it.
Any suggestions? How can I check myself to see if the drain line is clogged causing the water to back up and leak.
Old Jun 29, 2007 | 01:08 PM
Default RE: leaking air conditioning unit
what year and engine size?
Old Jun 29, 2007 | 01:24 PM
pepe's Avatar
2003 town and country...with 3.3L V6 OHV
Old Jun 29, 2007 | 04:21 PM
What happens is the outlet that is outside of the van when driving the air will force the water back into the hvac housing and stay inside. The o ring that thay are talking about is for the drain tube. IF they did that what they want to do is take out the housing and put a new seal between the firewall and the hvac housing. A cheaper and once was a tsb for this u apply RTV around the hose on the outside and seal up where the water would come back in. Or a way I have done it was make a tube at a 90 degree angle down so the water is directed down and air flow will not push it back into the cabin.
Old Jul 1, 2007 | 08:06 PM
rnkhoyt's Avatar
I had the same trouble recently w/03 Town & Country. Pulled back carpeting and padding to allow for placement of fan to aid in drying carpet. Purchased a Evaperator drain tube extension from Dealer for $7. Need to place over drain tube beyond slot in bottom to prevent water from running back along tube to firewall. (I applied some dishwashing liquid to make the extension tube slide easier. A little hard to get to, butis possible. May need a hose clamp. Didn't put one on mine though and has held fine for 2 months now. If you haven't already gone to the dealer, don't spend all that money until you try this first. I learned about it on this forum. Good Luck!
Old Jul 1, 2007 | 08:36 PM
Stretch's Avatar
Pepe --If you are using the recirculation mode on the A/C, don't. Your car will never build up enough air pressure in the cabin to force the water out the drain. The drain is probably behind the alternator on the firewall. You might try to see if you can unplug it with something from the engine compartment side.
Old Jul 7, 2007 | 05:11 PM
pepe's Avatar
THANKS FOR ALL THE ASSISTANCE....
mascu
Jun 9, 2009 06:28 PM
johnf
Sep 14, 2007 11:18 PM
CJ
Jun 9, 2007 09:35 PM
mckzach
Jun 6, 2007 03:28 PM
oakbri
Dec 13, 2006 11:27 PM
