low compression-2002 TC
Old Jul 16, 2012 | 01:58 PM
nelpasa's Avatar
Default low compression-2002 TC
What should I do to correct low compression? Replace rings?. replace head gasket? Anything else?
Old Jul 16, 2012 | 02:10 PM
check the valves for holding pressure
Old Jul 19, 2012 | 03:55 PM
nelpasa's Avatar
I added oil to the cylinders and the compression did NOT change, DOES that indicate BAD VALVES?
Old Jul 19, 2012 | 04:29 PM
possible
Old Jul 20, 2012 | 11:00 AM
nelpasa's Avatar
any suggestion based on data provided?
Old Jul 20, 2012 | 06:01 PM
u already know the prob fix it
Old Jul 21, 2012 | 12:11 PM
nelpasa's Avatar
Would you say is the valves, not the piston rings? If I do not have to buy rings that will be a big saving for me. If I had money to spare I would have gone to the dealer's service department.
Old Jul 21, 2012 | 05:12 PM
if the rings were bad the trans fluid would have brought up the compression U said it did not.
Old Jul 22, 2012 | 12:20 PM
nelpasa's Avatar
thanks for the advise. just trying to do the correct thing at the lowest cost....
Old Aug 10, 2012 | 12:47 PM
nelpasa's Avatar
Question
I grinded the valves with coarse grout and rechecked the compression. the compression went up to140 from 70, except on #1 and #3, which stayed low(110). Next I resurfaced the heads, regrinded the valves again and replaced the head-gaskets, now I am getting lower pressures than before resurfacing. Rechecked the compression with oil in cylinders but did not improve noticeable Could it be that I did not use fine grout?
PLEASE HELP
