low heat at idle-with rpm there is heat
Old Dec 17, 2007 | 09:32 AM
davet's Avatar
Default low heat at idle-with rpm there is heat
I have a 2000 dodge Grand caravan, 3.3 flex engine. The problem is, at an idle there is little or no heat coming from the vents, when the engine rpm is increased either by sitting still and just stepping on the gas or by driving it, the air from the vents warmsup and get hot. The coolant level is good.While driving, the temp gauge comes up to mid point and stays there, so the van is not overheating like a stuck thermostat.
Any ideas?
Old Dec 19, 2007 | 04:15 PM
Default RE: low heat at idle-with rpm there is heat
feel both heater lines to the fire wall if one is colder then the other u have a clogged core.
Old Dec 19, 2007 | 04:18 PM
moe's Avatar
moe
heater core or bad water pump .are you sure your system is full??did you look in radiator?
Nosmo
Nov 8, 2013 12:19 PM
John_Moore
Apr 18, 2013 10:01 PM
hinderjd
Feb 13, 2013 10:50 AM
Koolcbody
Feb 13, 2012 02:12 PM
69roadrunner
Jun 29, 2007 11:44 PM
